Does your UE Boom 2 speaker not properly pair with your phone, tablet, or other devices via Bluetooth? UE Boom 2 speakers are susceptible to a range of problems that could cause them to fail to connect to other devices using Bluetooth. Failing to connect the speaker to your device with Bluetooth may be another reason the speaker is not producing sound. Check the following possible causes to identify and solve the problem.
If your UE Boom 2 speaker is not producing any sound, see the UE Boom 2 Is Not Producing Sound problem page, instead.
Bluetooth Pairing is Not Enabled for the Device
Check to make sure that your Bluetooth pairing is enabled on whatever device you are trying to pair to the speaker. Select the ‘UE Boom’ from the list of devices, and make sure that the UE Boom speaker is ready to be paired with.
Bluetooth Pairing is Not Enabled for the Speaker
If your UE Boom is not connecting via Bluetooth, your speaker might not be in pairing mode. Make sure the speaker is in pairing mode by pressing and holding the Bluetooth pairing button on the speaker, which is located above the power button until you hear a sound. The Bluetooth LED light on the speaker should be blinking.
Speaker is Too Far From the Device
Sometimes, distance can cause problems when pairing two devices via Bluetooth. Move the device you are trying to pair closer to the UE Boom speaker and try to connect again.
Too Many Devices Are Connected
The UE Boom speaker can have a maximum of two devices paired to it at once. The speaker will not allow you to connect a third device or override one device with another. So, make sure all other devices are unconnected before trying to reconnect your desired device.
Additionally, your UE Boom cannot have two identically-named devices connected to it at once. Try renaming your phone while in your Bluetooth settings to make sure that there are not two identically-named devices connected to the speaker.
Device is Not Updated
If the Bluetooth software on your device is not updated, you may have trouble connecting to a newer device. Make sure you have the most recent software installed on your UE Boom by connecting the device to your computer with the Micro USB cable and installing the most up to date software patch. In some instances, the device you are trying to connect may have the out of date Bluetooth software, in which case you should make sure that the connected device has the most recent software installed.
Speaker Requires Factory Reset
If you have performed all of the above steps and your speaker will still not pair with your device via Bluetooth, the speaker may require a factory reset. To perform a factory reset, use the following steps:
  1. Turn on your UE Boom.
  2. Hold down the volume down button and the power button at the same time until you hear a sound. Your UE Boom will then turn off.
  3. Turn it back on and try to pair it with your device again.
Note that doing this many times in a row may harm your speaker, so refrain from doing this more than once or twice. You may need to also rename your phone in your Bluetooth settings while your speaker resets. This will prevent the speaker from having two identically-named devices connected to it.
Questions other people have asked about this
crwdns2935291:0crwdne2935291:0
Arielle Sampson
crwdns2935283:007/05/20crwdne2935283:0
17.131 crwdns2915208:0crwdne2915208:0
crwdns2944067:05crwdne2944067:0
Why I'm getting problems to connect spiker
Safiya Khan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
“Can’t find speaker” stated. Phone is held close to no avail. Any ideas?
Al Robinson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I try to connect I get “too far from speaker “even though I’m close. Any suggestions?
factory reset resolved the problem (not visible anymore event on already paired devices)
MS WCS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I tried to reset factory, didn't work out.
I got the problem with it to connect it with my bluetooth after i got my phone back from repair.
Now i need the app to connect with it. Even than it will not work to connect.
The problem is that i cannot connect and play any music with it..
Valerie Epic - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 22,424
