crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If you press the trigger buttons on your Turtle Beach Stealth Ultra and they are unresponsive, follow this page for possible solutions.
Residue Buildup Around Buttons
If your Turtle Beach Stealth Ultra controller has external residue preventing the trigger buttons from fully functioning, follow these steps to clear it out.
- Power the controller down. You can do this by pressing and holding the guide button (with the Xbox logo on it) for six seconds.
- Once the controller is off, pour alcohol onto a cotton swab or Q-tip. Please be sure not to directly pour it onto the controller.
- Use the cotton swab to work around the trigger buttons in question. Try to get it into the cracks and let the alcohol clear out the residue.
- Press the now-cleaned trigger button a few times to work the alcohol through.
- Wait for it to dry, and turn on the controller to test it.
Software Glitches
Often Bluetooth connection issues occur because of glitches with the software of either device in connecting. Sometimes these can happen at no fault of the user. The easiest solution is to perform a factory reset to clear all custom settings.
- Hold the x button until the lights come on.
- Press the plus button on the front of the controller.
- Press the Y button to enter the menu on screen.
- Navigate with the D-pad until you reach the system option in the navigation, select this option with the A button.
- Select "Reset to defaults" with the A button.
- Turn controller back on and try to connect to the console.
Bonjour je recherche une pièce détachée pour remplacer la gâchette de ma stealth ultra cassée en mode Trigger lock pendant le jeu ou trouver la pièce en dessous du Bumper .
REGIS-EYMARD - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
