crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Tablet Will Not Connect to Wi-Fi
Tablet is not showing the Wi-Fi symbol or will not let you use internet-related applications.
Wi-Fi Not Enabled
Ensure that Wi-Fi is turned on within the settings. If Wi-Fi will still not turn on then reset the tablet and attempt to connect again.
Connection Too Weak
Please make sure that the device is in a strong Wi-Fi area. Sometimes this means being within 50 feet of the wireless router.
Connection Not Found
Ensure that the appropriate Wi-Fi password is being entered. Also attempt resetting your wireless router or modem while searching for the wireless connection with your tablet.
Router and/or Modem Issues
If you are experiencing router and/or modem issues at home and they cannot be solved by doing a reset then we recommend calling your service provider to see if they can repair it.
Unresponsive Screen
The tablet's screen is unresponsive on a page and will not let you hit any buttons or it turned black.
Low Battery Life
Your screen may become unresponsive due to a low battery. Try attaching the tablet to the charger to see if it becomes responsive again.
Factory Reset Required
All technical devices can potentially glitch, causing the software to malfunction. If your screen becomes unresponsive, try a hard reset of the device, restoring it to factory settings. Before attempting a factory reset you may want to backup your device.
WARNING: Factory resets may erase all data on the device depending on which option you choose.
To perform a factory reset:
1. Hold either the + or - volume button and the power button at the same time until the screen goes black.
2. Let go of ONLY the power button until the Android logo appears.
3. Let go of the volume button and decide which option you want to perform (Wipe Data or Factory Reset).
4. Use the + and - volume buttons to scroll between the options and the power button to select one.
5. The tablet should say "Reset Now". Hit the power button again and wait until the reset is done.
Screen is Dirty
As a touch screen device, it is important to keep the tablet clean. A simple wipe down with a clean cloth should suffice. Ensure users' fingers are not dirty when using the tablet to prevent this issue.
Overheating
LCD displays emit heat against the touch screen surface when in use. High usage of the tablet may cause an excessive amount of heat to build up on the touch screen, causing the screen to not respond. Attempt to turn off the tablet and letting it cool down, then try to use the tablet again.
Problems with Supported Media Formats
The tablet will not let you open or use a certain file.
Supported Operating Systems
Make sure you are using a supported operating system. These include: Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.4 or later.
Supported Audio Formats
Make sure you are using a supported audio file format. These include: MP3, WMA (non encrypted), MP2, OGG, M4A, MA4, FLAC, 3GP, and WAV. If you are not using one of these formats, try to convert the file to one of the supported formats.
Supported Video Formats
Make sure you are using a supported video format. These include: AVI (H.264, DIVX, XVID), RM, RMVB, MKV (H.264, DIVX, XVID), WMV, MP4 (H.264, MPEG, DIVX, XVID), MPEG, MPG, FLV (H.263, H.264), and HD 1080P max. If you are not using one of these formats, try to convert the file to one of the supported formats.
Supported Image Formats
Make sure you are using one of the supported image formats. These include: JPG, JPEG, GIF, BMP, and PNG. If you are not using one of these formats, try to convert the file to one of the supported formats.
Tablet Not Holding Charge
The tablet does not respond to charging, dies unless plugged in, or dies quickly.
Electrical Outlet is Faulty
Make sure to check the outlet that the tablet is charging on. If the electrical outlet is not properly pulling electricity then it will be unable to charge your tablet.
Faulty Power Cord
Check the power cord to make sure it does not have any cuts or tears. This could hinder the pull of electricity through the cord. Just because outside tears are not seen, does not mean that it is not a faulty power cord. There could be tears inside the chord, as well. If your power cord is faulty it will need to be replaced.
Bad Battery
Over time, it is possible for a battery to go bad and no longer hold a charge. This can be checked by connecting a charger to the tablet. If the battery responds to the charging but dies when the charger is removed, then this is most likely caused by a bad battery which will need to be replaced.
Overcharging
Overcharging the tablet can cause your battery life to shorten. If a battery is charged too often, it will cause the battery to require frequent charging. If your battery requires frequent charging you may want to consider battery replacement.
Overloading RAM/CPU
When a tablet is in use, it drains the battery faster due to computer processing information used to run apps. Having too many apps open at one time can quickly drain your battery and make it seem as though it won't hold a charge. Attempt to close all apps and or programs and see if it improves performance.
Camera is Not Working
Camera will not open or is having problems taking pictures.
Low Battery
One of the main reasons why the camera application will not open when you attempt to open it is because your battery may be too low. The camera requires a certain amount of power to run, and if the battery is low it may not be getting enough power. Charge your tablet and the camera should begin working properly again.
Dirty Lens
If your pictures are blurry or dark, you may simply have a dirty lens. Clean dirt or smears off of the lens by gently wiping it with a clean, soft cloth.
Storage Full
If your camera is refusing to take photographs, your storage may be at full capacity. Be sure to check and see if your storage is full. You should be able to find this information in the settings. The Trio Stealth G4 only has 8GB of storage. If your storage is full, but you do not wish to delete anything, this device does feature a MicroSD card slot that you can use to add additional storage for the device.
Camera is Damaged
If your camera is unresponsive and will not take photographs, the camera might be damaged. If this is the case, the camera will need to be replaced.
Emily Dorsey
crwdns2935283:008/26/15crwdne2935283:0
434 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Fall 2015 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Fall 2015crwdne2935289:0
WCU-VIRTUE-F15S1G3
crwdns2935297:048crwdne2935297:0
I have a pro and it say there is a unknown problem with google I cant down load a new browser they stop sorporting this one
Vernon Nunnery - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 1,298
