crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Toshiba Thrive 4G Troubleshooting
Sound is not coming out from speakers
If the sound is not working, check the volume settings on your device. You can adjust the volume to your liking on this page. If you adjust the volume, and it is still not working, check to make sure the mute option is not on. If you check to make sure the device is not muted, and it still is not projecting any sound, the speakers may be blown, and need to be replaced.
Device will not turn on
If your device will not turn on, make sure the battery is charged, or the power cord is plugged in properly. Check the on/off indicator to see if the device is on or off. If the device still will not turn on, the battery may need to be replaced.
Display does not work
the display over time may fade, based on battery life, and the common uses of the user.
Battery will not charge
“The device won’t last nearly as long as it did when first purchased. This is common for batteries in devices such as tablets to deteriorate over time. Make sure the battery is charged, and the charging cable is working correctly. If the cable is not working, you will need to replace the charging cable. If the charger is working, but the battery won’t charge, it is likely your battery is dead, and needs to be replaced.”
Courtney Campbell
crwdns2935283:010/22/14crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Shastany Fall 2014 crwdns2935289:0UMass Dartmouth, Team 1-1, Shastany Fall 2014crwdne2935289:0
UMASSD-SHASTANY-F14S1G1
crwdns2935297:036crwdne2935297:0
Device turns on, and won't do anything after that! Help please
ladams7 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 28
crwdns2959996:0crwdne2959996:0 454
