crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device is not powering on
The massage gun does not turn on.
The battery is dead
It is possible that your device is not powering on because the battery is dead and in need of recharging. If the battery is dead and charging it does not help then you may need a new battery.
Power button malfunction
If the power button is broken, this could prevent the device from powering on.
Device not charging
The massage gun does not charge or hold a charge when plugged in.
Incompatible or broken charger
The charging cord may be loose, damaged, or incompatible. If you are not able to charge your device this could be the case.
Charging port issues
If the device has a damaged charging port, it can interfere with the charging process.
Device is noisy
The massage gun is loud when it is on.
The gasket is missing or has worn out
If the device is producing excessive noise then it is possible the small gaskets around the attachments that help to reduce noise around the tip have worn down or are missing.
Loose components or massage head
If the device is noisy and rattling due to the vibrations, then the components could need tightening. Make sure the massage head is properly fastened into place, a loose attatchment can cause noise.
Device is producing weak or no vibrations
The massage gun does not create a powerful vibration or doesn't vibrate at all when powered on.
Excessive force when using
If you are pushing hard while using the massage gun this could cause the vibrations to be weak.
Loose massage head
If the massage head isn't properly attached then vibrations could be weak or not at all.
Massage head is not moving
The massage gun head does not produce any vibrations.
Motor Problems
An issue with the motor or connections to the motor could lead to no movement from the massage gun head.
Blockage within the massage head
If the massage head is in contact with an obstruction like debris, then the massage head will not move. Make sure to clear any debris that may be affecting the massage head.
crwdns2944067:030crwdne2944067:0
My gun when plugged up says 99% charge but when I unplug it does not come
On at all or the display does not come
On
Jody! - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My gun is doing the exact same thing . I have even used it that much and now that I need it is not working . How can I fix this? Please help thank you.
Tanece - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My massager is doing the same as everybody else’s. It says 99% once you turn it off unplug it nothing
Hiran Lugo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Jody
Did you ever get a answer to your problem with the TOLOCO EM26 Messager?
Alan Peters - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same with my massage gun. We have barely used it and it's shows fully charged, but doesn't work. Piece of crap.
Q G - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
