crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
TI-5130 won't turn on
No matter what position the on/off switch is in your TI-5130 won't turn on.
Not plugged in
It is possible that the TI-5130 has come unplugged, or you have a blown fuse. Make sure that the calculator is plugged into a live outlet.
Damaged power cord
Power cords can be damaged over time by pets, desk chairs and other equipment. Check that the power cord is not kinked or broken; such as chew marks from pets or a pinched wire. It is possible that you need to replace the power cord.
Blown transformer
Transformers can wear out overtime or be blown by a power surge. It is possible that the transformer has blown and needs to be replaced.
The paper is coming out blank.
The TI-5130 will turn on, calculate and feed paper but the paper is coming out blank.
Ink cartridge is dry or empty
Ink Cartridges can dry out over time from continuous use or lack of use. It is possible that the ink cartridge needs to be replaced.
TI-5130 won't feed paper
The TI-5130 will turn on and calculate, but it is not printing the paper is not feeding.
Printer switch is set to "OFF"
You may have accidentally turned the printer switch to "OFF." Check that the printer switch (located in the left top corner of the keyboard) is set to "ON."
Paper is not loaded
Your paper roll may not be properly loaded into the paper feeder. Check that the paper roll is feeding through the paper slot (located in the back.)
Printing unit has failed
Over time parts that are used on frequent basis, such as the printing unit can start to wear out and can fail. It is possible that you need to replace the printing unit.
The display is dim
The calculator will turn on but the digital display is dim.
Burnt out display
The display uses florescent lighting. Just like light bulbs the lights can burn out over time. The Display may need to be replaced.
Sticky keys
Key(s) are stuck either in the up or down position.
Key(s) move but they stick or resist movement
Keys can get stuck overtime due to sticky residues spilling or contacting the keys. Check to see if there is any residue on or around the key. Lightly dip a towel or q-tip in rubbing alcohol then gently rub the residue to remove it.
Key won't move
Something could have gotten underneath the key. Remove the face plate and remove anything that may have gotten under the key.
Shannon Perkins
crwdns2935283:009/17/15crwdne2935283:0
652 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 crwdns2935289:0USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015crwdne2935289:0
USFSM-STEWART-F15S1G2
crwdns2935297:0180crwdne2935297:0
where is the fuse for this unit located?
Greg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where is the fuse for the texas instruments ti 5130 located? I have no power to the unit when switch is turned on.
WHICH SLOT IN THE BACK??? the instructions are terrrible. there is one slot in the BACK that had units that block entry. There is a slot at the TOP OF THE ADDING MACHING - AT THE BACK - IT SAYS TO INSERT THE CREASED PAPER INTO THE SLOT AT THE BACK UNTIL THERE IS RESISTANCE. WHAT THE HELL DOES THAT MEAN??? WHY DOESN'T IT show IN THE PICTURE EXACTLY WHERE TO INSERT.
i TRIED BOTH. I GOT RESISTANCE. THE PRINTER BUTTON IS ON. THE DEVICES IS PLUGGED IN AND TURNED ON. i HIT THE ARROW KEY]-- PLENTY OF NOISE BUT NO PAPER MOVEMENT. wtf
WELLS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 5,399
