Schematics & Pinout Information
Link: Series Controller Technical Information
crwdns2916044:0crwdne2916044:0
All attributions go to acidmods user RDC 🐐 for schematics and pinout information.
Preface
When referring to failure/fault, this can be caused by a multitude of things related to any referred component this could be related to:
  1. Logic failure i.e. no control signal to component.
  2. Power failure i.e. no/Insufficient power to component.
  3. Internal failure i.e. short to ground.
  4. Other i.e. Mechanical fault like a broken trace or disconnection from pads.
Common Symptoms
Symptom: No vibration
  1. Low battery voltage
  2. Disabled in Accessories settings
  3. Faulty vibration motors
  4. Faulty motor drivers
  5. Faulty MCU
Symptom: All face buttons + D-Pad are pressed.
  1. Faulty L16A chip
  2. Faulty MCU
Symptom: Low Battery Warning (Using AA batteries)
  1. No voltage to voltage divider
  2. Faulty voltage divider to SoC
  3. Faulty SoC
Symptom: Triggers at 100%
  1. Faulty trigger hall-sensor
  2. Faulty SoC
Symptom: No/Intermittent connection when using USB-C Cable
  1. Faulty USB-C Cable
  2. Faulty USB-C Port
  3. Faulty Filters on Data +/- lines
  4. Faulty SoC
Symptom: Joysticks stuck at 100% after replacement
In some firmware, aftermarket hall effect/TMR causes issues where they error out for whatever reason and causes the sticks to hard pan randomly. Resistors are required to fix this see: Series Controller Joystick Error Fix. If this does not resolve your issue please see list below
  1. Faulty replacement joystick
  2. Joystick feedback line shorted to ground (LSX,LSY,RSX,RSY)
  3. Faulty SoC
Symptom: Xbox Logo flashes constantly, No sync wirelessly
  1. Faulty connection between MCU board and power board
  2. Faulty wireless circuit
  3. Faulty SoC
Symptom: No Power and high pitched whine
  1. Faulty component shorted to ground, common components are in wireless circuit RFF2 or T2 and caps on 5V to 3.3V converter.
Please feel free to edit where relevant.
Neville Davids
crwdns2935283:007/02/18crwdne2935283:0
876 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 378
crwdns2942667:0crwdne2942667:0 3,201
