crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unresponsive Display
The screen has a weird color or does not show the image.
Dead Pixel
Sometimes small black dots appear on the screen from either dropping or manufacturing flaws. They can only be fixed through screen replacement.
Screen Damaged from Presure
Pressing into a screen with fingers can leave ghost finger impressions behind. They cannot be fixed beyond screen replacement.
No Sound
There is no sound coming from the device.
Volume Turned Down
The volume can be turned down accidentally. Turn the dial towards the back of the device to increase the voume.
Mute Button Engaged
Sometimes the mute option is accidentally hit or forgotten about. Hit the mute button to unmute DVD player.
Headphones Plugged-in
If headphones are plugged in they will override the normal volume functions. Unplug them and normal speaker function will be resumed.
Speakers Broken
If volume does not return there may be damage to the speakers and should be replaced.
Disk Will not Read
The disk in the DVD player is not working.
Disk is Dirty
Discs are read by lasers and their absorbance; fingerprints can absorb lasers and scatter them. Clean the disc with a clean cloth.
Disk is Scratched
Scratches damage the plastic of the disk and behave similarly to finger prints. Either repair or replace the disc.
Quiet Drive
The CD drive makes a sound when spinning the DVD. If there is no sound then it means it is broken and replacement is necessary.
Device will not Turn On
The DVD player is not turning on or is on for a short period of time.
Power Switched On
Hands can accidentally flip switches on the side, shutting off the device. Flip the power switch in the on direction.
Battey Life is Poor
If the battery is old, then it may have degraded internally. To expand the battery life or to simply charge the device, replace the battery.
Charger is Loose
Charger components can come loose. Make sure that all components are completely plugged in.
Buttons do not Work
The buttons on the DVD player are not functioning.
Buttons are Dirty
Dirt under buttons can cause contact issues or can cause buttons to not fully compress. Clean the buttons thoroughly.
Buttons are Jammed
Jammed buttons will not register. The keys need to be unjammed by cleaning or replaced.
Drive will not Open
The DVD player will not open to place a DVD inside.
CD Placement
If a CD is not correctly inserted it can jam the inside of the drive lid. Press the open button and make sure the CD is inserted correctly.
Open Button Jammed
If the open button is jammed then the lid will fall open, close the lid with tape until it can be fixed by cleaning or replacing the button.
Faulty Spring
If the screen no longer holds tension lid will lock in place. Use a prying device to open the lid after pressing the open button. The spring will need to be replaced.
crwdns2944067:029crwdne2944067:0
Sylvannia DVD player will not attempt to read disc; no lights, no mechanical sound just flashing light on display for about 1 second then screen goes totally blank.
BJ Lucas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a black screen with no sound and it is fully charged
williams.leasa25 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When they put a DVD in it shuts off and turn back on when I will shut back off
cringe t - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Main screen shows picture, the other screen shows colored lines, but no picture
vtaylor333 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
