crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
When you're trying to track your SteelSeries Rival 3, does it not detect on screen? Use this troubleshooting guide to help diagnose why.
Obstructed Optical Sensor
  • Turn off the mouse
  • Flip it over and inspect the optical sensor for dust, lint, or debris.
  • Use compressed air to gently remove particles.
  • If needed, lightly wipe the area with a microfiber cloth.
  • Turn the mouse back on and test tracking performance.
Faulty Batteries
  • Check the battery level in SteelSeries GG software.
  • Replace the AAA batteries with fresh ones if power is low.
  • Restart the mouse after replacing batteries to ensure proper reset.
Damaged Circuit Board
  • Open the mouse and check the circuit board for any visible damage like burn marks, cracks, or loose connections that could be affecting the sensor.
  • If you see a loose solder joint or damaged small component near the sensor, try carefully re-soldering or replacing that specific part if you have the tools and experience.
  • If the board itself is cracked or badly damaged and repair isn’t realistic, replace the entire PCB or just replace the mouse altogether.
Nayeli Aviles
crwdns2935283:002/04/26crwdne2935283:0
710 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-1, Johansen Spring 2026 crwdns2935289:0Texas Tech, Team 41-1, Johansen Spring 2026crwdne2935289:0
TTU-JOHANSEN-S26S41G1
crwdns2942667:0crwdne2942667:0 186
