crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
When you're trying to scroll on your SteelSeries Rival 3 Wireless does it not move? Use this troubleshooting guide to help diagnose why.
Internal Buildup
  • Turn off the mouse.
  • Use compressed air to blow around the scroll wheel.
  • Gently rotate the wheel while blowing air to dislodge debris.
  • Test the wheel after cleaning.
Damaged Internal Wheel Scroll
  • Test the mouse on another computer to confirm the issue.
  • Remove the mouse skates, unscrew the four screws to access scroll wheel.
  • Clean the scroll wheel
  • Reassemble the mouse.
  • If the problem persists, contact SteelSeries for support.
  • Check warranty status and request a replacement if eligible.
  • Check Statues Here: RMA, Warranty, & Refunds – Support
Faulty Sensor
  • If your SteelSeries Rival 3 Wireless won’t scroll and the scroll wheel sensor (encoder) is faulty, open the mouse and check if the scroll encoder is loose, dirty, or misaligned near the wheel assembly.
  • Clean the scroll encoder using compressed air or a small amount of electrical contact cleaner and spin the wheel repeatedly to see if that restores smooth scrolling.
  • If cleaning doesn’t fix it and the encoder is worn out or damaged, desolder the old scroll encoder and replace it with a compatible one, or replace the mouse if repair isn’t worth it.
Nayeli Aviles
crwdns2935283:002/04/26crwdne2935283:0
710 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-1, Johansen Spring 2026 crwdns2935289:0Texas Tech, Team 41-1, Johansen Spring 2026crwdne2935289:0
TTU-JOHANSEN-S26S41G1
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 889
