crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
When you press and hold the CPI button, does Bluetooth not appear on the screen? Use this troubleshooting guide to help diagnose why.
Faulty Batteries
  • Check the battery level in SteelSeries GG software.
  • Replace the AAA batteries with fresh ones if power is low.
  • Restart the mouse after replacing batteries to ensure proper reset.
Dongle Interference
Use these steps to reduce wireless interference between the mouse and USB receiver.
  • Plug the USB receiver into a front USB port or use a USB extension cable.
  • Keep the receiver within a few feet of the mouse.
  • Avoid placing it behind metal objects or under a desk.
Damaged Circuit Board
  • Remove the batteries and open the mouse and inspect/clean the PCB with 90%+ isopropyl alcohol to confirm whether it’s corrosion/connection-related or true board damage.
  •  Repair the specific fault by reflowing cracked solder joints or replacing the bad part (switch/encoder/connector) if you have soldering tools.
  • If the PCB is cracked, traces are burned/lifted, or repair isn’t practical, replace the entire motherboard/PCB with a compatible Rival 3 Wireless board (or replace the mouse).
Nayeli Aviles
crwdns2935283:002/04/26crwdne2935283:0
710 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-1, Johansen Spring 2026 crwdns2935289:0Texas Tech, Team 41-1, Johansen Spring 2026crwdne2935289:0
TTU-JOHANSEN-S26S41G1
crwdns2936753:030crwdne2936753:0 114
crwdns2959996:0crwdne2959996:0 821
