crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Failing to Hold Charge
Device does not have a long battery life; power is off soon after charging.
Clogged/Faulty Charging Port
First, check the inside of the charging port; it may have dust or dirt in it, keeping the device from charging effectively. If the port is clogged, use an air duster to clear it.
Faulty USB Cable
If the charging cable is damaged then your device won’t charge properly. Check the USB cable with a different device, such as a cell phone or computer, and if the cable is unresponsive then it is defective and has to be replaced.
Faulty Battery
If the charging port and USB cable are working, but your device is powering down prematurely, then your battery may be damaged or faulty and needs to be replaced.
Connectivity Issues
The speaker is not pairing or connecting to other devices.
Poor Wi-Fi Range
The connected device is too far away from the device and needs to be brought within range. If the connected device is close to the speaker, but it is still giving connectivity problems, the speaker may have a poor Wi-Fi range.
Failing to Connect to Multiple Devices
The speaker is able to connect to a single device, but does not connect to other devices afterwards. Simply disconnect from the first device, then try connecting to another device again.
Faulty Aux Cable
If the Aux cable is properly inserted into the speaker and a second device, and there is no connection established, or the connection constantly drops out, the aux cable may be faulty and needs to be replaced.
Clogged Aux Port
If it is determined that the aux cable is in good condition but there’s still a problem with the connection, try cleaning the aux port as it may be dirty and preventing a good connection.
Static Sound
When you turn on device, you detect a static sound in the background.
Poor Wi-Fi Range
A reason for the static/muffled sounds could be a poor Wi-Fi range. This can easily be fixed by moving closer to your router, within approximately 150 feet, for the best Wi-Fi connection.
Broken/Bent Speaker Grille
If the front panel of the speaker is broken or bent then the audio will sound warped or have static. If the panel has any visible deformation then it will need replacing.
Unresponsive Buttons
Buttons are not responding.
Dirt Build-Up
Grab a wet cloth or wet wipe. Gently and thoroughly wipe down the targeted area to collect dust. If the dust persists to be a problem, you will need to be more precise. Grab a small, thin object such as a wooden toothpick. Carefully use the point of the paperclip to motion around the area and remove the remaining dust.
Buttons Can't Be Pressed
In this case, there is likely an obstruction of some kind underneath the button. Therefore, proceed to remove the button. Then, remove the obstruction completely.
Overheating
Device is getting increasingly warm to the touch.
Dust In Speakers
First, you will need to remove the cover. After, dust the area around the speakers thoroughly and completely. Proceed to dust the battery as well. Finally, dust off cover and put cover back on.
Device Location
If the device is powered on, you will need to turn off the device by pushing the power button. Make sure the device is not in a warm area, such as direct sunlight. If available, place the device in a cool area and on a hard flat surface. For future usage, the device should be kept in a cool place and on a hard flat surface.
Zoe Neumann
crwdns2935283:002/09/16crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 2-50, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-50, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G50
crwdns2944067:051crwdne2944067:0
My device blinks red when charging and it gets hot near the charging port. Any help on this?
emmah511 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
UPDATE
I took off the cover and its the piece on the right of it that is heating up. I connected my phone to it and couldn't hear anything but a buzzing static and faint music playing.
Can some one help me? I just bought my Soundbot and it won't stay to what I put it on. If I put it on the mirror it won't stay but my brother has the same Soundbot and his is old but his stays on the mirror or any other surface. Should I send it back to Amazon which is where I bought it from? How do I keep it on what I put it on
Daniel Berberian - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have soundbot sb271 and the language is chinese! how do i change it?
ohbeone - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My SoundBot only connects to my phone when its off. When I turn it on, it doesnt connect. Can someone help?
Ariahius Snow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 56
crwdns2959996:0crwdne2959996:0 36,982
