crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the power indicator light on your Sony WH-CH520 does not turn on and engage its power-up sequence, follow this troubleshooting guide.
Charging Can’t Be Done
In the event, the headset is plugged into a wall outlet via a USB charging cable and adapter, but it doesn't seem to be charging, take the following steps to troubleshoot.
  • Make sure you are using a correct charging cable. Ensure you are using the proper USB charging cable, a USB Type-C.
  • Additionally, make sure that it is plugged into a USB AC Adapter that supplies an output current of 500 mA (0.5 A) to properly deliver the required charge to the headphones.
Exposure to Water or Sweat
If the headset gets wet and is powered on, components may burn out or malfunction. To avoid damaging the inner components of your headset after potential exposure to liquids;
  • First disconnect from power: be sure to remove the USB-C charging cable from the port.
  • Open the outer shell of the headset: removing plastic casings.
  • Air dry inner components.
Damaged USB-C Port
If the USB-C Port is unable to connect to a charger
  • Try a different charging cable or outlet. Check to see if the charger works for another device to confirm it isn't damaged.
  • Check that the temperature of the headset is between 59° and 95° F to ensure optimum charging
  • Check the port for debris that may be blocking the charging port or corrosion using a flashlight.
  • If there is corrosion, replace the charging port.
Degraded Battery
If the battery won't power on after charging or is corroding
  • Batteries degrade over time with usage and overcharging.
  • If the battery life has been shortened or won't turn on without being plugged in, the battery likely needs to be replaced.
Harry Jones
crwdns2935283:010/18/24crwdne2935283:0
347 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Konn Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Konn Fall 2024crwdne2935289:0
UMASSD-KONN-F24S2G2
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 1,331
