Camera won't turn on
No matter what you do, you can't get the camera to turn on.
Make sure you twist the switch to the "On" position
Turn it to the right until it snaps and you hear the click
The switch is located on the top right portion of the camera.
Faulty batteries
It is possible that the batteries in the camera may be dead. Try testing new batteries.
The batteries go into the compartment on the bottom right of the camera.
If none of the above options work, see below to see how to fix the LCD screen.
The flash is not working
The flash compartment is falling off of the camera and is only being held by a few dangling wires.
It is possible that the flash is not on
Press Fn and check if the flash is on
The bulb may be broken
It is possible that the bulb in the flash is broken. If so, it will need to be replaced.
You cannot see through the optical viewer
You cannot see any picture when looking through the optical viewer.
There may be something in front of the viewfinder
Move or clear anything that may be in the way.
The glass is broken
If the glass is broken then find a way to replace it.
The lens may be broken
Try a different lens on the camera and see if it works.
Broken LCD screen
The screen will not turn on.
The camera may be turned off
If the screen does still not turn on, see below.
Check to see if there is any visible damage to the screen
If the screen is cracked or falling apart from the camera, you will need to replace screen.
You can find a replacement screen online.
The camera lens fell off
I cannot take any pictures because the camera has no lens.
The camera needs a separate lens to take a picture
Place the lens it on the camera, twist, and the lens should stay on
If the lens still won't stay, its possible the lens is broken
There are a plethora of different lenses on the internet that all serve different purposes. They will all work with the camera. The right lens just depends on your photography preference.
john bogart
crwdns2935283:001/21/15crwdne2935283:0
281 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-7, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 6-7, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S6G7
crwdns2935297:048crwdne2935297:0
My camera showing msg Camera error
Intizam thanvi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My camera displays a "camera error" message when I take a picture. I have to turn it off and on again, sometimes several times, and then it can take pictures normally again. But sometimes, even while I'm taking pictures, the camera error message appears.
I would appreciate any help you can give me in fixing this error.
Thank you.
Tavo perez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 2,685
