crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
Sony Ericsson Will not turn on/Blue screen
Either you are unable to turn on the phone or a blue screen is displayed.
Battery Problems
If your phone does not turn on try one of these solutions:
  • Plug charger into phone and let phone charge for about 5 minutes and then try turning on phone again
  • Remove battery, replace it and try turning on phone again
  • Remove battery, replace it, and plug in the phone and then try turning it on
Blue Screen
If your phone only displays a blue screen remove the battery and then replace it. If this does not work it is a hardware problem.
The Screen is Locked
You have problem accessing your phone because it says that you need a password.
Security Code
If your phone says that you must enter a password to access the phone, enter the code "0000", this is the default unlock code built into the phone.
But if that does not work, that means that for some other reason your phone's code has changed and you must contact your wireless provider so they can give you the unlock code.
Text message problems
You have problems sending text messages and or picture messages.
In order to send text messages your phone needs the number to the service center.
To set the service center number.
  • Messages -> Settings -> Text Messages -> Service Center. If there is no number on the list -> Add and enter the number (you may need to contact your wireless carrier to get the number) ->Save
Richard
crwdns2935283:004/16/10crwdne2935283:0
3 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-12, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 7-12, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S7G12
crwdns2942667:0crwdne2942667:0 1,777
