Phone doesn't turn on or works slowly
You cannot get your phone to turn on or it is not working as fast as it should.
Phone needs to restart
Restart your phone every day to free your memory. Your phone is like a mini computer so it can have data overload.
Battery is discharged
Make sure your battery is fully charged. If you don't let your phone charge correctly it affects the battery performance.
If the battery is completely drained, it may take up to 30 minutes of charging before the battery-charging icon appears on the screen.
Memory card is damaged
Remove the memory card (if you have one). If the phone turns on after removing the card you might need a new memory card.
Screen is not displaying properly
Your screen is cracked or unexpectedly colorful.
Screen is damaged
The screen could be damaged and needs to be replaced. Follow the repair guide for replacing the screen. Screen Replacement
Contacts do not appear
All my contacts disappeared!
SIM card is malfunctioning or broken
Make sure your SIM card is properly installed in the phone and functioning. Replace the SIM card if it is damaged or broken. Follow the repair guide for installing the SIM card. SIM card installation
Phone doesn't charge or the battery level is low at all times
After charging your phone all day it still says low battery.
Battery connectors need to be cleaned
Remove the battery and clean the connectors. This creates a better connection which improves the charge of your battery. If you need more help follow the manual on how to replace your battery. Battery Replacement.
Battery is worn out
The battery is worn out and needs to be replaced. If you have owned your phone for more than two years there is a high possibility your battery needs replacement.
Charger connection is poor
The phone is not properly connected to the charger or the battery connection is poor. Make sure you connect your phone correctly before you let it charge.
Phone keys do not work
Not even excessive force will produce a key to work.
There is a Motherboard problem
The motherboard is the most important component of your phone so if it is damaged you definitely need to replace it.
Wires are loose or keys are broken
The keypad has a poor connection to the board which means some wires are loose. See keyboard repair manual for information on how to replace it. Keyboard Replacement.
No sound comes out of the phone
Your phone is giving you the silent treatment.
Phone volume is low or off
The volume on the phone is low or your phone is on silent. Go to your phone setting and increase the volume and/or take your phone out of silent mode.
Phone speakers are broken
The speaker on your phone might be damaged.
Volume key is broken
Volume key has a poor connection making it unresponsive.
Diego
crwdns2935283:010/09/11crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-31, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-31, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G31
phone shows no network coverage or emergency calls only
Rajbir Dabas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a problem with Sony W580i i turn it on lights and keyboard turn on but screen turns on but no picture, screen is on when u look at it at a angle, how can i turn it on?
Roko Šicel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 7,641
