crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone won't turn on
Battery not charged
Make sure that your battery is charged before trying to turn on your phone.
Screen is dead
The screen could be dead and would need to be replaced. See our screen installation guide.
Motherboard is failing
The motherboard is failing or has failed, and would cause the phone to not turn on. See our motherboard installation guide.
The keypad is not working
The keypad could not be working and would not allow user input to be received by the phone.
Phone is working slowly
Memory capacity reached
Your phone might be slowing down because all of it's memory is being used. Try restarting your phone. If the problem persists, look into performing a reset or master reset.
The motherboard is failing or has failed, and would cause the phone to work slowly. See our motherboard installation guide.
Battery dies quickly
Unneeded functions running
Make sure bluetooth on your phone is turned off. Turn down your screen's backlight. Don't listen to music or browse the internet for too long.
Defective battery
Your phone's battery might have internal hardware problems and require replacement. See our battery installation guide.
Battery not charging
Cable unattached
Check to see if your phone's charging cable is fully plugged into both the phone and the outlet.
Defective battery or cable
Your phone's battery or cable might have internal hardware problems and require replacement. See our battery installation guide.
Keypad Unresponsive
Keypad is loose or broken
Your keypad has probably gotten worn over time from use and needs replacement.
Motherboard problem
There might be a hardware problem with your motherboard requiring replacement. See our motherboard installation guide.
Can't connect to network
Sim card problem
Make sure your sim card has been properly installed on your phone. If it has been and the problem persists it may need replacement. See our sim card installation guide.
Screen is black
Screen damaged
Your screen may be damaged and need replacement. See our screen installation guide.
Motherboard failure
No sound coming from phone
Volume is low
Check to make sure your volume is not 0 and raise it until you can hear.
Speakers broken
Your phone's speakers may be broken and require replacement. See our sound box installation guide.
Phone experiences freezes and/or crashes
Motherboard problem
It is likely that your motherboard is damaged and needs replacement. See our motherboard installation guide.
Battery problem
Your battery could be damaged causing power problems. See our battery installation guide.
Bluetooth not working
Make sure bluetooth is on and in range
Make sure that your phone and the other device using bluetooth are both charged and have bluetooth turned on. Then make sure both devices have set their bluetooth options to visible. Finally make sure that both objects are within range of each other.
Minnal
crwdns2935283:007/09/12crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-1, Regan SU 2012 crwdns2935289:0Cal Poly, Team 1-1, Regan SU 2012crwdne2935289:0
CPSU-REGAN-SU12S1G1
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,496
