crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Soda is not Fizzy Enough
Finished soda is flat, it does not have enough bubbles.
Water Temperature is Incorrect
Using warm water generally results in fewer bubbles. Cold water is recommended for best results.
Start with Carbonated Water
Using carbonated water, that is unflavored, will result in more bubbles. You will be adding additional carbonation and the soda will have more overall fizz.
The Loader Tab is Immobile
When pressure is applied to the lever, it does not move.
Incorrect Starting Angle
The nozzle and tab should be angled away from the SodaStream before the bottle is inserted. The tab may be caught, try gently lifting the tab away from the body of the machine.
Hear Gas Escaping
You hear a high pitched noise coming from your machine
Carbonation Canister is Loose
If the Carbonation canister is not set firmly, you may hear excess gas leaving the machine. This can be caused by having worn out or too many washers, or if the canister is not screwed in enough. Make sure the canister is securely fastened before and after use.
*Note: Recent carbonation bottles have been recalled due to the possibility of bursting under pressure. If this issue of gas escaping occurs, and your bottle was purchased between Feb. 2016 and Jan. 2017, consider changing out the canister and checking if your bottle was part of the recall.
Gas Tube is Loose
The 2" long white gas tube on some models can become loose. This is located in the connection area and goes inside your bottle. You will feel the CO2 escaping as you press the lever on the top of the machine to dispense the gas. Tighten down and proceed as normal.
SodaStream is Unresponsive
When trying to operate the SodaStream, nothing happens.
Too Many Sealer Washers
If there are too many washers present the carbonation bottle will not be able to hold in place. Be sure to check the carbonation attachment area with tweezers. If you pull out one little black rubber ring and there is a second one present underneath, leave the second one and keep the extra one for future use.
Washer Needs to be Replaced
After time, the sealer washer can become less firm in the carbonation attachment area. This will cause the carbonation bottle to shift or not hold firm once attached. To change, take a pair of tweezers and pull the little black rubber ring out of the area where the carbonation bottle attaches to the SodaStream. Replace this with another washer and try to reattach the carbonation bottle. If the bottle holds firm the machine should respond once again.
Nothing Turns On
If you are trying to use your SodaStream, and nothing is happening (i.e. there are no lights on your three-level carbonation indicator), you may need to replace the battery or interface chip located within the carbonation button on the front of the machine. See our guide for instructions.
Leaking during carbonation
When the SodaStream is operating, there is leaking around the opening of the soda bottle.
Bottle is not in Correct Place
Make sure the bottle is completely upright. The carbonation nozzle has downward force and may spray if the bottle is inserted at an angle.
Bottle is not Fully Attached
The nozzle must be fully inserted in the clear plastic bottle to avoid leaking. When inserting the bottle go in at an angle, screw in the bottle, then gently push the lever.
Incorrect Starting Liquid
Always use water or unflavored carbonated water with your SodaStream. Using other liquids such as juice or a soda that has gone flat you risk damaging your SodaStream. Using other liquids may result in a fizzy mess.
Hailey Smith
crwdns2935283:002/20/17crwdne2935283:0
1.591 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G4, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G4
crwdns2935297:084crwdne2935297:0
crwdns2944067:0221crwdne2944067:0
help!! my soda stream metal unit will not slide down over bottle
Roberta Talefich - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Lets get one thing straight
Sodastrem is $@$*
My first top of the line unit POWER failed after 3 months
The next unit I got doesn’t work AT ALL
WTF!~!~!
Richard B - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I push the buttons, all of the lights flash and nothing happens.
D Farr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same problem im having have u solved it yet ???
Brandi white - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Ditto All the lights are flashing and nothing happens
Trevor Wilkins - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 43
crwdns2936753:07crwdne2936753:0 305
crwdns2936753:030crwdne2936753:0 1,520
crwdns2942667:0crwdne2942667:0 407,019
