crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Back to Sirius Stiletto 2 Device Page
Device won't turn on
The device will not power on after pushing the power button.
Battery is drained
The battery is the most common reason why the device will not turn on. Check to see if the battery is charged by plugging in the power adapter. If the device does charge but will not power on, the battery will need to be replaced.
Check to see if the battery is also properly inserted.
To replace the battery, check out Sirius Stiletto 2 Battery Replacement
Broken Adapter
If the device is not charging, the power adapter may need to be replaced. The power adapter charges the battery so if the adapter is broken the device will not charge correctly.
Device does not have any audio
There are no sounds coming from the device.
No headphones are plugged in
Check the volume to see if it was not turned off. Make sure headphones are plugged into the device and make sure the headphones work on other devices to ensure that the headphones are working.
If replacing headphones does not work, the audio jack might need to be replaced.
Faulty volume button
Check the volume to see if the sound was not turned off. If the sound does not change with each press of the volume rocker this may be indication that the part of the device that registers the volume being changed is no longer functioning. If that is the case then the entire device would need to be replaced.
Device is not getting any signal
Displays "ACQUIRING SIGNAL" message
Interference
If there is no signal, make sure you are in a open area. Enclosed spaces will usually weakens the signals.
Faulty antenna
If there is still no signal, the antenna may not be capable of receiving signals properly. At this point, damage to the antenna would cause it to be irreplaceable and the would warrant replacement of the entire device.
Device's buttons are unresponsive
Pushing buttons on the device doesn't do anything.
Locked
Check to see if the device is "Locked" by looking at the power button. If the power button is pushed up, push the power button back down to "Unlock" the device.
Scroll Wheel is not working
If the buttons on the device are still not working, the scroll wheel may not be working properly and needs to be replaced.
To replace the scroll wheel, check out Scroll Wheel Replacement
Device screen is dark/bright
The content of the screen is not visible enough
Brightness Setting has been changed
Check the brightness settings by going to Setting --> Display --> Brightness. Raise the setting if your screen is too dark. Lower the setting if the screen is too bright.
LCD Display may be faulty
Worst case scenario, the LCD Display my not be working properly, or may need to be replaced.
To replace the LCD display, check out LCD Display Replacement
Music Library does not show
No music or recorded files shows up in your MP3 library
Wrong file type
Make sure you have files that the device can play. Supported audio files for this device are .mp3 and .wma file types.
microSD is not working
Check to see if the microSD is properly inserted. The location for the microSD is behind the battery. If the music still does not show up, the microSD may be corrupted and needs to be reformatted.
To access the microSD, check out microSD Replacement
Benjamin Her
crwdns2935283:001/21/15crwdne2935283:0
567 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-6, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 6-6, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S6G6
crwdns2942667:0crwdne2942667:0 1,757
