crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Shark Rocket IX141 exceeding normal operating temperatures when used? If so, follow this troubleshooting guide.
Dirty Filter
A dirty filter may be causing your Shark Rocket IX141 to overheat. There are two filters you should check. Dust filters are located on the bottom of the dust cup. The motor filter is located under where the dust cup was located on the vacuum, simply grip the ring in the middle and pull to remove it. Both should be rinsed with water ONLY! Do not use soap! Let the filter(s) dry for 24 hours before use.
If the filters cannot be cleaned, you will need to replace them. See Pre-Motor and Felt Filter Replacement and Post-Motor Filter Replacement.
Full Dust Cup
When the dust cup reaches full capacity, this may result in the Shark Rocket IX141 overheating. To release the dust cup, press the grey button with an arrow pointing toward the cup and pull upwards. To open the lid, press the grey button with the trash can.
Blockages in Airway(s)
If the Shark Rocket IX141's overheating does not improve after emptying the dust cup and cleaning the filters, there may be blockage in the vacuum's airways.
Blockage in Brush Roll
A clogged brush roll may cause the vacuum to overheat. The brush roll is located on the underneath of the floor nozzle. Pick up the floor nozzle and inspect the brush roll. Clear all debris from the brush roll by hand or with scissors. For a wider angle on the brush roll, use a coin to rotate the circular locks counterclockwise and lift the plastic away from the floor nozzle.
If this does not remove improve the quality of your brush roll, it may need to be replaced.
Blockage in Floor Nozzle
Behind the brush roll, the floor nozzle commonly gets blocked. To check and clear this blockage, locate the gray circular locks on the underneath of the floor nozzle. Use a coin to rotate the locks counterclockwise and lift the plastic away from the floor nozzle. Once removed, check the airway leading to the rest of the vacuum, and remove any debris.
Blockage in Wand
After detaching the wand, inspect the interior for any possible blockages. In some situations, you may need to shine a light through the wand to view it better. When you've found the blockages, clear them out fully. Run water through the wand or use a long object to reach inside if necessary.
Blockage in Handle Base/Motor
Once having detached the wand, inspect the the hollow parts of the handle base. Remove the dust cup and filters, and check for blockages where they were connected.
Vance Andersen
crwdns2935283:009/04/24crwdne2935283:0
116 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Utah Tech University, Team 1-5, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-5, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G5
crwdns2942667:0crwdne2942667:0 523
