No Picture / Black Screen
Verify that the console is turned on and that the game is fully inserted and securely positioned. If so, clean the dust out of the game port using a can of condensed air (aerosol) or a cotton swab (Guide: cleaning the game port).
Won’t Turn On
Verify that the AC adapter chord is plugged in. Check the AC adapter chord for any obvious tearing or fraying. If problem persists, check for a disconnected solder point at the power port once the Sega Genesis is taken apart (Guide: disassembling the device). If necessary, re-solder.
Static Screen
Sega Genesis is not registering with the television.
Verify that the RF cable is fully plugged in to the television and console and that there are no tears or problems with the cable. Also, check for disconnected solder points at the RF cable port once the Sega Genesis is taken apart (Guide: disassembling the device).
Controller Not Working Properly
Could be caused by a faulty controller or controller port.
Verify that the controller is fully plugged in to the console. If so, try a different controller in the same port. If this controller works, then there is a problem with the first controller (click here to buy a new controller). If this second controller doesn’t work, then there is most likely a problem with the controller port.
No Sound
There is a problem with the RF cable (could be a connection problem or a faulty cable).
Verify that the RF cable is plugged in. Try wiggling the cable around and if this doesn’t work, then it needs to be replaced. (click here to buy a new RF cable)
Click here to go back to Sega Genesis Device Page
Erik Bjornstrom
crwdns2935283:010/04/10crwdne2935283:0
852 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-29, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 3-29, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S3G29
crwdns2944067:024crwdne2944067:0
just got the system for free with the power cord. no games yet. but plugged it in to see if power light turns on and it doesnt light up. does a game have to be inserted in order for the power light to light up? dont wanna buy games if it doesnt work. thx.
pencejesse - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So my sega will turn on just fine boots any game is in perfect condition but the sound is just weird like it will have the regular sound but with a buzz like a static noise like the console is dirty or clogged I took it apart and cleaned making sure I got every thing and still makes that weird sound idk if it’s just the old ness of the console or my RF cable is bad or I need to clean better but reply if you know.
MaxsonTroubleshoots - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
^^its the sega genesis atgames console.
The atgames genesis is NOT a true genesis. It is a cheap plug-n-play games console. If you depress the power on the front you indeed will see a power light, so this one is broken.
You are better off getting a real genesis used as these units are notorious for sound issues.
Howard Casto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just picked up a high definition sega Genesis and a few games. Hooked it up the next day, popped zero tolerance in and it worked great. Played that for about half an hour, took it out and popped in a different game. Nothing.
John Latimer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 172
crwdns2959996:0crwdne2959996:0 105,812
