crwdns2862666:0crwdne2862666:0
crwdns2862667:0crwdne2862667:0
crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2862670:0crwdne2862670:0
This wiki does not have a summary. Help improve this page by writing one!
crwdns2869080:0crwdne2869080:0
crwdns2862673:0crwdne2862673:0
Error
crwdns2936873:0crwdne2936873:0
Example:
[flag|<flag id>]
Current text:
[flag|device stub]
Phone Won't Turn On
When the power button is pressed, screen remains black, and the phone won't turn on
Bad keypad connection
Make sure that you are holding the end button for at least 2 seconds. If after pressing the button for at least two seconds, your phone still does not turn on, hold the button for 3 to 4 seconds several times. If it does not turn on, it is possible something is lodged below the keypad. If this is the case, the keypad may need to be removed and cleaned under.
Bad battery
Your phone may have insufficient power to turn on. Try plugging your phone into your Samsung power charger. On the inside screen of the phone a battery power symbol should be displayed. If this symbol is not displayed, then it is an indication there may be something physically wrong with your battery. The Battery may need to be replaced.
Bad logic board
If none of the previous steps worked, the logic board may require replacing.
Phone Won't Ring
Phone fails to make a sound to alert for an incoming call
Phone settings
Make sure that your phone is properly turned off silent mode. To make sure you are out of silent hold the pound button (#) for a short period of time. Your screen should flash with the words, “Exit silent mode” or “Entering silent mode”, depending whether or not it is or is not in silent mode. Your phone may also be in vibrate mode. If so a small icon of your phone shaking will appear on your screen. Push the volume keypad on the side of your phone to increase the volume
Bad Keypad Connection
If there is a bad keypad connection when you press the pound button your phone may not change from silent mode to ring. A faulty keypad connection could also occur with the volume keypad on the side of your phone. If this is the case, the keypad may need to be removed and cleaned under.
Bad speaker
It is recommended that you retry some of the previous steps. If they don’t work again, then there may be something wrong with your speaker. If that is the case the speaker may have to be replaced.
Keys won't work
Pressing keys illicits no response from the phone
Dirty Keys
Your keys might have dirt in them that keeps the keystrokes from being registered. This may happen on some or all keys, and the effected keys might be hard to depress or have a gritty feel. If this is the case, the keypad may need to be removed and cleaned under.
Bad logic board
The circuitry for the keypad is on the logic board of the phone, it may be damaged in some way. If this is the case, the logic board may need to be replaced.
Phone won't charge
When plugged in the phone fails to charge
Debris in the charging port
The phone's charging port may have debris lodged in it such as pocket lint, dirt, sand, etc. If this is the case, repair may be as simple as removing the debris with a paper clip or toothpick.
Dead battery
Batteries will sometimes lose their charge potential after long usage. If this is the case, the battery may need to be replaced.
Bad charger
It is possible no current is getting to the phone because of a broken charger. If this is the case, the charger may need to be replaced.
Bad outlet
It is possible the wall outlet the charger is plugged into is not supplying current to the charger. If this is the case, try another outlet.
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
156,822 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,337
