Phone will not turn on
No matter what you do, your phone will not turn on.
  1. Try charging the phone.
  2. Make sure battery is properly oriented.
  3. Replace the battery.
  4. Check buttons to see if they need replacement or have damage. (see Step 4)
Samsung Portable Dualband Tri-Mode Battery Replacement
Sound Problems
There is an echoing sound when you use your phone.
  1. Make sure the echo is not due to using the phone a small enclosed area.
  2. Make sure the echo is not caused by a lack of signal by checking the signal bar on the phone.
  3. If there is an echoing sound, try replacing the speaker.
Samsung Portable Dualband Tri-Mode External Speaker Replacement
Speaker Volume
The volume is too low or different from the regular volume.
  1. Make sure the sound is turned up.
  2. Try replacing the speaker.
Samsung Portable Dualband Tri-Mode Internal Speaker Replacement
Keypad will not respond
Some or all of the buttons do not respond or do something different from their actual purpose.
  1. Check to see that phone is adequately charged.
  2. Check to see if buttons are clean or if anything is obstructing the keypad.
  3. Check the buttons and the keypad to see if they are damaged or need to be replaced.
  4. If unresponsive, replace keypad buttons.
Samsung Portable Dualband Tri-Mode Keypad Replacement
Broken Antenna
Replace antenna.
Samsung Portable Dualband Tri-Mode Antenna Replacement
Broken Front Flip Plate
Replace front flip plate.
Broken screen
Replace screen.
Samsung Portable Dualband Tri-Mode Motherboard Replacement
Broken connection covers
Replace connection covers.
Barbara
crwdns2935283:003/26/14crwdne2935283:0
413 crwdns2915208:0crwdne2915208:0
Clemson, Team 6-2, Benson Spring 2014 crwdns2935289:0Clemson, Team 6-2, Benson Spring 2014crwdne2935289:0
CLEM-BENSON-S14S6G2
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 685
