crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Will Not Turn On
LCD screen and camera do not respond when the power button is switched from off to on.
Battery Is Dead
Remove the battery from the compartment on the bottom of the camera and charge it in its charging unit. Full charge is reached after at least one hour.
Battery Is Inserted Incorrectly
Battery does not need to be forced into place. The blue tab should slide into a groove that holds the battery in place on the negative-positive side of the battery.
Battery Is Old
When batteries do not hold a significant charge anymore, a new battery needs to be purchased.
LCD Screen Is Broken
If the screen remains black and unresponsive consider a screen repair.
Battery Cover Does Not Close
Battery door remains open, exposing the batteries so that they may fall out.
Wrong Battery
The battery does not match the Samsung NX1 camera. Read the battery label to make sure you have the appropriate battery type.
Battery Is Not Fully Inserted
You must push the battery all the way down, so that the spring is compressed, and the blue tab locks the battery into place.
LCD Screen Will Not Turn On
LCD screen is completely dark or the image is hard to see.
Battery Is Dead
LCD Screen Brightness
Use the auto settings to adjust the screen brightness or use the brightness button located below the screen on the top right of the camera to make the display brighter.
LCD Screen Is Detached from the Camera
Check the connecting cable on the underside of the screen to make sure that it is attached and not damaged. If it is damaged, consider a cable repair.
If you see a visible crack or a rainbow tint on the LCD screen, consider a screen repair.
Camera Will Not Autofocus
Images taken are blurry.
Camera Is in a Different Setting
Use the dial on the top right side of the camera to change the setting to AUTO. Push the button in the center of the dial to lock the setting dial in place.
Shutter Button Is Pushed Too Quickly
When taking a photograph push the shutter button down halfway and allow a brief moment for the camera to focus before continuing to push the shutter button all the way down.
Wrong Lens Attached
If you have a long lens on the camera and the subject of your photograph is within close proximity, you may not be able to zoom out the lens enough for the camera to focus. Try a shorter or macro lens.
Camera Flash Does Not Work
The flash will not fire when you want it to.
Flash Setting Is Not On
Push the flash button located on the front left side of the flash, so that the flashbulb pops up.
Battery Is Low
Remove the battery from the compartment on the bottom of the camera and charge it in its charging unit. Full charge is reached after at least one hour. The flash will not fire if the camera’s batteries do not have a sufficient charge.
Flashbulb Is Burned Out
Check the bulb for visible damage. If the bulb does not fire at all, consider a repair.
Flash Release Is Not Working
The release for the flash may be jammed or broken. If the flash button does not open the flash, consider a repair.
Hannah Patrick
crwdns2935283:002/24/16crwdne2935283:0
903 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Leahy Spring 2016 crwdns2935289:0USF Tampa, Team 1-4, Leahy Spring 2016crwdne2935289:0
USFT-LEAHY-S16S1G4
HDMI PORT BROKEN. WHERE can i repair
Choppers V - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 49
crwdns2959996:0crwdne2959996:0 1,527
