crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Turn On
No matter what you do, you can't get your Camcorder to turn on.
Drained battery
If your Samsung HMX-W200 has not been used in a while and will not turn on, the first thing to check is if the battery is dead. Connect your camcorder to the USB charging cord and connect to a power source. Your camcorder screen should turn on shortly showing it is accepting charge, if not, you may have a faulty battery and will need to replace it. Refer to guide on battery replacement.
Faulty USB charging port
If you determine that it is not a faulty battery causing your camcorder to not turn on, you may have a defective USB charging port. To remedy this problem, you will need to simply replace the broken USB charging port.
No screen display
As a last resort, if the battery and USB charging port are both properly working, the LCD display may be defective. A malfunctioning display will make it seem as if the camcorder is completely defective, when in fact it is just a broken display. And if so, the display will need to be replaced. For instructions on replacing the screen, refer to this guide.
Broken Screen
LCD screen is shattered or cracked.
LCD screen is broken
A cracked or broken screen can make it difficult or impossible to use the camera. The only solution would be to replace the LCD screen. For instructions on replacing the screen, refer to this guide.
Video Quality is Low
The quality of the video is not as expected.
Dirty lens
Dirty lens can result in low-quality images. Wipe the device to clean any dust that might be on the lens.
Out of focus
If the recording by the camera looks blurry or does not posses the expected quality, the lens could possibly be out of focus. Restart the device. If the problem is not fixed, you would have to go to the camera settings and calibrate the focus manually. As a last resort, change the device settings back to default.
Faulty lens
If none of the other methods to improve the video quality worked, you might need to replace the lens. This guide will help you through the process.
No Audio Playback
Camcorder does not record audio.
Dirty microphone
Get a toothpick or a q-tip and clean dirt out of microphone hole.
Faulty microphone
The microphone may need to be replaced.
Pictures not being Saved
Pictures or videos are not being found.
No SD card installed
Look in SD card slot to make sure that SD card is installed. If not insert SD card into slot.
Try new SD card
If there is an SD card in slot, but pictures are still not being found or saved, replace inserted SD card with a different card.
Case is Broken or Unsealed
The casing of the camera may be broken or does not seal properly.
Faulty casing
If the casing is broken or does not close entirely, the camera will no longer be waterproof or shockproof. To prevent damage to the exposed components, replace the back/front case parts.
Haya Barakat
crwdns2935283:010/04/16crwdne2935283:0
542 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-6, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 3-6, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S3G6
crwdns2935297:084crwdne2935297:0
Hello,
I have small issue…
water got into the memory’s inlet,so every time I put the memory it says (memory error!)
what should I do? please help
MoNeR 96 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 2,081
