crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone Will Not Turn On
Phone is not turning on. This is most likely due to a dead battery
Press and Hold Power Button
Check to see if the phone is actually on. Hold the power button for 5 to 10 seconds. If the phone still does not turn on proceed to the next step.
Charge Phone
The phone's battery may be dead. Plug the phone into a charger and charge the phone for about 10 minutes. Then, try to hold the power button again.
Replace Battery
If this does not work the battery would need to be replaced, see this replacement guide for further instructions.
Other
If the phone does not turn on still there may be an internal problem, mainly the motherboard. You can change the motherboard by following this replacement guide.
Camera is not working
Camera is not working properly. Camera is not taking pictures.
Replace Camera
The camera is most likely broken either internally or externally. The best option is to change the camera shown in this replacement guide.
Keypad Buttons Unresponsive
The keypad buttons aren't responding when pressed. This is probably due to high use of the phone which would wear out the buttons and the internal hardware of the phone.
Button is Broken
The buttons will need to be replaced, be it one button or several buttons that are not working. Follow this replacement guide to repair a single button, multiple buttons, or the keypad itself.
No Connection
There is also a possibility that the wires got loose and will need to be reconnected or replaced. Follow this replacement guide to check the connections of the keypad. If the wires are connected properly and the button still does not work, the wire may have internal damage and will need to be replaced.
No Sound
There is no sound coming out of the phone, music, ringtones, notification sounds, etc. It is very likely that there is internal damage to the speakers.
Faulty Speakers
Speakers are most likely broken and would need to be replaced. You can follow this replacement guide.
Vibration Not Working
The component of the phone that makes the vibration may be broken or connection may be lose. In the same replacement guide it will show the vibration component and its connections and how to replace it if necessary.
Speakers aren't Connected
The volume buttons may not be connected properly to the sound and will need to be reconnected. The connections are shown in the same replacement guide above. Also, the speakers may not be connected. Reconnect the wires using the guide above. If the sound still does not work, the wires may have some internal damage. To fix this, get new wires and solder them to the screen and speakers. Use the above guide for disassembly.
Exterior Damages
Scratches, screen cracks, not functioning, etc...
Front Screen
This is the screen which is visible when the phone is closed. We are still looking for a way to fix this part of the phone. The phone will most likely need to be replaced.
Inner Screen
This is the screen which is visible when the phone is opened. We are still looking for a way to fix this part of the phone. The phone will most likely need to be replaced.
Phone Broken in Half
The phone is snapped in half, broken at the hinge. Most likely the phone will need to be replaced.
Michael Huang
crwdns2935283:003/30/15crwdne2935283:0
403 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Shastany Spring 2015 crwdns2935289:0UMass Dartmouth, Team 2-5, Shastany Spring 2015crwdne2935289:0
UMASSD-SHASTANY-S15S2G5
my phone keeps beeping while charging?
wsperron - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The bottom half still working just can't see my txt message
Brittney Warrick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine has a mind of its own, turning itself off even when on a full charge. Solutions anyone?
Emory Lankford Griffis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,925
