First Steps
Here is a group of five things to check that doesn’t take much digging and may solve your problem fast. Take a quick look!
Recent Garbage Disposal Installation
Have you just replaced your disposal? If not, skip this. When your dishwasher is supposed to be draining, check to see if you hear any water flowing into the disposal body. No water suggests that the knockout plug in the dishwasher connection on your garbage disposal wasn’t removed. (Yes, I’ve done it.) If you see water pouring out of the air gap fitting on the rim of your sink, this is almost a certainty. You will need to remove that plug with a flathead screwdriver and a hammer. You will likely have to remove the disposal to reach it more easily. Unplug or shut off the power to your disposal if you have to do this.
Reset Dishwasher/Incomplete Wash Cycle
Check to make sure the last wash cycle was completed properly—if your dishwasher has a “Clean” indicator light, it should be illuminated. If not, the wash cycle may have been interrupted. Close the door and press the Start button. To reset your dishwasher, just unplug it or turn the circuit breaker off for about 5 minutes. Then, try running a cycle to see if it drains.
Full Garbage Disposal
The disposal may be full of waste and just needs to be run. Do so. Sometimes, an item will obstruct the dishwasher drain opening. If you have an air gap, there is only gravity pressure to move debris, and it may not be enough to move it fully.
Clogged Filters
On the bottom of the tub in your dishwasher are a number of filters. If these get clogged, the dishwasher will struggle to drain and may not drain completely. Remove the lower rack, remove the filters as directed by your owner’s manual, and clean them thoroughly. Reinstall them and test to see if the unit will drain.
Clogged Air Gap
The air gap is that funny bump (usually chrome with a couple of slots in it) that sticks up on the rim of your sink near the faucet. When the dishwasher empties, the water flows through the air gap. The air gap prevents dirty water from your drains from entering your dishwasher (water doesn’t flow uphill). Sometimes, it gets clogged with food debris, and the water can’t get into the drain plumbing. You can usually lift off the cap and check for a clog. Clean up any that you find.
If none of these items was the problem, the next group of causes and solutions are a little more involved but are good items to check if your dishwasher still will not drain.
Clogged Drain
Make sure that the residential drain is not clogged, as this can cause the dishwasher drain to clog. You would probably already have some suspicion that the drain was clogged, but you might also have a drain that was slow.
- Fill the sink and make sure it drains freely when you release the water.
If it works, go on to the next item.
Jammed Water Level Float Switch (5E or E5 code or blinking “Delicate” light)
Many models have a float disc in the bottom of the wash tub that senses water level. If it gets jammed in the up or floating position, the dishwasher will often have an error code and may stop draining before it is empty.
- Check if there is any debris or detergent buildup that causes the float to stick in the up or full position.
Clogged Pump Impeller
Older models (400,700,800 series) will have a circulating pump impeller that is underneath the filter located on top of the round sump. The impeller wheel can become clogged with debris and refuse to pump, which may affect draining even though it isn’t the drain pump. The passages associated with this can also become clogged with food debris or grease. Take note of where the screws come from as you remove them. Here’s a link to a helpful video. If the impeller is ok, or your model doesn’t have one, move to the next step.
Clogged Tubes and Hoses
NOTE: You will need to pull the dishwasher out from under the counter in order to perform the next several checks.
You should have the following tools and items:
- A straight slot screwdriver,
- A #2 Phillips screwdriver,
- A pair of slip-joint pliers will also be helpful for disconnecting the hoses.
- A ½” open-end wrench or a small adjustable wrench for disconnecting the water supply hose.
- Four wire nuts, so you don’t have to reuse the old ones. Get ones that are suitable for #12-#16 wire.
- A multimeter (not essential but helpful to test components)
- A wet-dry vacuum set up to pick up water is very helpful but not essential.
You will need to do the following steps to pull the dishwasher out:
- Shut off the power to the dishwasher, either at the circuit breaker panel or by unplugging it if it is connected to an outlet under the sink. This is most critical with units that are hardwired rather than connected with a plug.
- If the dishwasher is hardwired, you will need to open the connection box (usually located at the lower right front of the dishwasher behind the kickplate)and actually disconnect the wiring.
- You will need to disconnect the water supply (usually at the left front of the dishwasher at the bottom behind the kickplate). The ½” wrench is useful here.
- You will need to disconnect the drain hose, which is best done at the location where the hose connects to the building plumbing (usually under a nearby sink at the garbage disposal).
- Remove the screws securing the dishwasher to the counter or cabinet.
- These will either be immediately above the top rim of the dishwasher or on either side of the dishwasher in the door opening. (If the latter is the case, there may be small covers over the screws)
- Pull the unit out, making sure that nothing kinks. The next step is to check the drain path for clogs and kinks. You will also want to check the parts built into the dishwasher.
Case Break
On some models, there is a plastic module called the case break with a loop water passage formed in it. This loop has a small opening (an air vent or vacuum break to prevent siphoning) that can trap debris occasionally and slow or stop drainage. It is mounted to the side of the dishwasher, usually to the left, looking from the front, but you should check both sides. It also functions as the water inlet port.
- If you find debris, you may be able to remove it with a wire or with water from a hose.
- A wet-dry vacuum cleaner may also be used to clear the loop.
External Drain Hose
First, check the entire length of the hose for kinks or partially crushed places (like where the hose goes through a hole in your cabinets. Clogs can form at such spots.
- The drain hose to the household drain can be disconnected from the case break using the slip joint pliers to free the hose clamps.
- You can try pouring water in the hose from the garbage disposal end to try to flush out debris or use a flexible solid wire to push out debris if possible.
- Check the inlet to the garbage disposal. Clogs can form in the inlet that cling very firmly, and the dishwasher flow is not powerful enough to push them through.
Here is a link to a helpful video. If everything is ok go on to the next possible cause.
Internal Drain Hose
The drain hose leading from the pump to the case break may also clog with debris. Usually, there is a check valve either in or near the hose that can jam shut or only partially open, which will not allow the unit to drain fully. In some cases, the check valve is a flap that we will cover later.
If none of these items were clogged, move on to the next step.
Drain System Issues
Clogged Sump
- Remove the filter screens and any cover over the sump and check for clogs or debris in the sump. These will prevent your machine from draining.
- Use a wet-dry vac if possible to clean out any debris in the sump.
- If you use a vacuum, be careful of the check valve, which may be in the sump and could be damaged or sucked up by the vacuum.
If everything is ok, go on to the next possible cause.
Check Valve
These units have either a ball check valve in the pump discharge or a flapper check valve in the sump near the drain pump. Both can get stuck. Make sure that they are free and any debris is cleared out. Sometimes the flapper valve can get twisted, and this may cause a 5E (or blinking “Delicate” light) error (no drain) because the unit will drain too slowly, and the drain pump shuts down before it is completely drained.
Pump Issues
A dishwasher that fails to drain but has no clogs leaves only a few items to check. At this point, listen to your dishwasher when it is trying (or should be trying) to drain.
- If you hear no noise at all, that points to a failed drain pump.
- If you hear a humming noise, it suggests a jammed drain pump.
- If you hear a sound like the pump is running (but no flow), it indicates
- an impeller problem
- a clog in the pump itself.
These will apply to models that have a separate drain and circulation pump arrangement. (Most models)
Failed Drain Pump
No drain pump noise can indicate a failed pump. It might also be too quiet a hum to hear. You will want to test the resistance of the drain pump after removing it
- The drain pump on most models is mounted so that it can be removed from the sump by just rotating the pump motor a partial turn clockwise until it releases. There will likely be a retaining tab that you will have to lift with a flat-blade driver.
- You can access it from under the dishwasher or sometimes from the side.
- Check the resistance of the pump it should be 25Ω +/- 10%
Jammed or Clogged Drain Pump
Your drain pump can be jammed by small plastic pieces. This will usually produce a hum. Sometimes a clog will allow the pump to run but prevent it from pumping.
- You can check from above in many cases by removing the sump filters and looking into the low point of the sump where the pump inlet is located.
- To make certain that the pump is not clogged, remove it as described above in the failed drain pump section.
Defective Impeller
Your pump may have a defective impeller with broken or twisted blades. It may also have come loose on its shaft. Check this carefully.
Failed Water Level Sensor
Occasionally the water level sensor will stick. We checked this earlier for units with a float-type sensor. The other type is mounted on the case break assembly and has a float that blocks light from a sensor. If the float sticks, you will get No Drain error codes (5E or blinking delicate light), and the drain system will shut down. You may find that the machine has drained fully but won’t go on in the cycle. If you find that the float is sticking, it is best to replace the water level sensor part. If the float switch is ok go on to the last item here.
Faulty Control Board
When you have reached this point, the likely cause is the control board. A definite check is to see if the board puts out the proper voltage for the drain pump when the pump is supposed to be running.
