Return to Device Page
Phone won't turn on
Drained/bad battery
Charge it, or buy a new battery.
Disconnected Wires
Open up the phone (see dis-assembly guide). Check to see if there are any loose wires. If there are, try to solder them back into place. If there are not or if the soldering does not work, your display screen is probably broken.
Broken Display Screen
You will have to replace the display screen.
Faulty Logic board
If the battery and the screen are not causing the problem, you may have to replace the logic board.
Display is Discolored or Otherwise Faulty
Bad Logic Board to Display Screen Connection
Open up the phone (see dis-assembly guide). Check to see if there are any loose wires (namely between the display screen and the logic board). If there are, try to solder them back into place. If there are not or if the soldering does not work, then there might be a problem either with the display screen or the logic board.
It is more likely that the problem is with the display screen so you can try replacing that
Broken Logic Board
If replacing the display screen doesn't solve your problems, then unfortunately it is probably your logic board that is defective. Replace the logic board.
Cannot make or receive calls
Bad service
Check with your service provider to make sure you are in your service ares.
Sound won't work
Check volume
Make sure the volume level is high enough to hear.
Loose connection
The speaker may not be connected properly. You will need to repair this connection.
Keys don't work
Dirty keys
Dirt or debris may have gotten into the keypad. If the dirt doesn't easily come out, you may have to remove the keypad to clean.
Phone Turns Off When Unplugged
Dead Battery
If the phone turns off as soon as you unplug the charger, your phone battery might be dead. If so, you will need to replace it.
Bad Charge Connection
Try blowing on or using an air cleaner to clean out the plug or the charging port in the cell phone. If this does not work, disassemble the phone and clean the port.
Broken Charger
Your charger unit may be faulty and may need to be replaced.
Kristina
crwdns2935283:004/05/11crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 12-35, Maness Spring 2011 crwdns2935289:0Cal Poly, Team 12-35, Maness Spring 2011crwdne2935289:0
CPSU-MANESS-S11S12G35
Samsung zeal keypad stop working displays number but not letters when switch to keyboard stays on phone mode with numbers to dial but no letters to text.
David - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Samsung zeal keypad stop working displays numbers but not letters when switch to keyboard stays on phone mode with numbers to dial but no letters to text.
crwdns2959996:0crwdne2959996:0 4,686
