crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device won’t turn on
When you press the power switch to the on position (I symbol), the orbit sander does not turn on.
Power Switch is broken
 Verify the power switch is not damaged. Check for visible damage or loose sliding action. If it is damaged, you will need to ++replace the power switch.++
Power Cord issues
A quick check of the outlet can determine if it is the issue and/or a check of the Power Cord for damage. If the Power Cord has cracks, exposed wires or other damage, you will need to ++replace the Power Cord.++
Loose Traction Pad
Pad is not adhering to device.
Velcro Pad is Dirty
Check to make sure the pad’s velcro is adhering to the device. If not, check to make sure the velcro on the pad and device are clean and free of dirt. Clean the device’s velcro gently with a spray bottle of water.
Velcro Pad is Damaged
First loosen the screws on the velcro pad.  Take off the velcro pad and use a vacuum or a suction device to remove dust from screws and screw holes on sander.  Replace and position velcro pad so that the pad lines up with the screw holes and tighten each screw a little bit at a time until tight to ensure even pressure over the whole velcro pad to the sander.
Device overheating
The Orbit Sander begins to heat up quickly or unexpectedly gives off a burning smell.
Overuse
The Orbit Sander begins to heat up quickly, after a prolonged period of use. Allow the Orbit Sander to sit for awhile and cool off before attempting to use again.
Vents Blocked or Covered
Make sure to keep hands off of air vents. Periodically check that nothing is blocking the air vents. If the vents are blocked due to dust make sure to clean it out before using the Orbit Sander again. Then verify dust bag exhaust is clear as well, remove the dust bag from the sander and make sure the exhaust is clear of debris and the bag isn’t overflowing with dust.
Bad Brushes or Assembly
After repeated use (perhaps faulty) brushes or the armature assembly might need to be replaced. The Orbit Sander heating up quickly is a sign that this might need to happen. Refer to the ++replacement guide for Brushes and Assembly.++
Bad Motor
IF all other troubleshooting has been attempted and the issue persists, the motor might be faulty. If you notice a burning smell or sparks, it is very likely the issue. To fix this issue, you will need to ++replace the motor.++
Weak or No Power
The Orbit Sander turns on but does not spin or spin fast enough when being applied to the work surface.
Bad Power Source
Check the outlet connection, make sure the sander is plugged into the outlet. It can become loose and cause this issue. Then check the Power Cord, if it is damaged, refer to the ++Power Cord replacement guide.++
Too much pressure
You might be putting too much pressure on the work surface. While maintaining a firm grip on the Orbit Sander, avoid blocking vents, release some of the downward pressure you are putting onto the work surface.
Bad Motor
Traction Pad Ineffective
Your Orbit Sander is not effectively sanding the intended surface.
Not enough pressure
If your orbit sander has a moderately new sander pad on it and the orbit sander is still ineffective, ensure that you are applying enough pressure to the sander.  This provides increased friction from the orbital sander to the surface which will increase effectiveness. NOTE: Make sure to maintain a proper firm grip on the Orbit Sander to avoid losing control or causing damage.
Daniel
crwdns2935283:009/17/19crwdne2935283:0
639 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G5, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G5, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G5
My Ryobi Sander is not holding the sandpaper in place.
The black bar that holds the sandpaper in place on a spring is broken. Is there a replacement piece on this?
Anne Taylor
anneataylor@gmail.com
Anne Taylor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my sander is leaving black smugges in the tub i am sanding, why
kelly johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 13,793
