crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Battery not working
The battery is not charging so the power drill will not turn on.
Battery isn't pushed in all the way
Make sure you properly center the battery then push it in enough for you to hear a click. If the battery is in all the way and the drill still wont power on, you may need to purchase a new battery.
Battery does not maintain power
If you already ensured that the battery is properly inserted and the drill still doesn't work, try putting the same battery on another drill to be certain that the problem is with the drill and not the battery itself. If the battery doesn’t work on another drill it is safe to say it is dead and a new one will need to be purchased. You can check on this guide for more details about getting a new battery.
If the problem is internal
If the battery is still having trouble, a possible underlying cause may be the internal wiring. In order to fix this problem  you will be required to open up the battery itself by removing the screws. From there, look for loose of broken wiring. Anything that may look unnatural to the battery may be the cause of your problem.
Drill bit not being able to be inserted
The drill bit holder is not properly holding the drill bit.
Clamps may be too tight or loose
You can adjust the tightness of the drill bit holder by turning the chuck.Turning the chuck right will tighten the clamps while turning them left will loosen them. Make sure your clamps are adjusted properly so that it may fit your drill bit.
Something may be jamming the drill bit holder.
Try to make sure to keep the drill bit holder clean and completely empty before use. Broken pieces of steel or dirt may be in the holder itself so be sure it is completely clean so that the drill bit may go in properly. If the drill bit is empty but either still wont full clamp or fit the drill bit then you can try to use a different drill bit to ensure the problem is with the drill itself. If the problem persists, you may need to purchase and replace a new drill bit holder for the drill. You can check on this guide for more details about getting a new drill bit holder.
Trigger does not work
When you squeeze the trigger the motor doesn't seem to be responding so the drill wont function.
Something internally may be jamming it
If the trigger is jammed internally you will have to open the drill and find the obstruction and remove it. You can open it by unscrewing the screws that run along the entire drill.
Trigger is broken
There might be a problem with the wiring within the drill so you will have to unscrew and open it so that you may either try to re-link the connection from the trigger to the motor. If the trigger remains broken after you re-link the wires then you will have to replace it by opening the drill removing the trigger and  exchanging it for a new trigger.
Magnet isn't functioning properly
The magnet hold the screws not currently in use all together and helps hold the screw in use in place.
The magnet is on the wrong side
If the magnet is on the wrong side it might've been placed incorrectly when the drill was being put together. Try finding different objects that generally stick to magnets and see if they stick or not. If it doesn't work with that side try unscrewing the drill so that you may remove and flip the magnet so that is on the correct side.
The magnet is missing
If the magnet itself is missing it will need to be replaced. Unscrew the screws on the drill to open it up and replace the magnet holder with a new magnet for the drill.
Reverse option fails to work
The reverse switch on the drill can hinder the user greatly. If the user makes a mistake it will be very difficult, almost impossible, to reverse that mistake. Also if the user wishes to take something apart held together by screws they would not be able to.
If this is an internal issue:
A solution to solving this problem can be to remove and replace the switch by unscrewing the screws on the drill to see if the switch is jammed or caught on something. If so remove the obstruction and place drill back together.
If this is an external issue:
If the reverse switch is jammed externally due to a sticky mess or an obstruction, simply remove the obstruction or clean away the sticky substance to the best of your ability using a minimal amount of damaging liquids. If neither of these problems are relevant then you may have to replace the switch.
Carissa Keung
crwdns2935283:010/31/19crwdne2935283:0
413 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S2-G6, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S2G6
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 1,620
