crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Poor/Lost WiFi Signal
Poor and delayed video and occasionally not receiving notifications. Ring, Motion or Live View failing to connect or taking more than a couple of seconds to connect.
WiFi Router Channel Crowded
Most routers are automatically set to switch channels to the least crowded. While this is the case, some must be done manually. Ensure that it is enabled by following the following link: https://www.howtogeek.com/197268/how-to-...
Bad WiFi Router Placement
Bad router placement can be the reason why there is a weak or no WiFi signal, as routers do have a limited reach. If this is the case, move your router to a location that is within 200 feet of the Ring Doorbell.
Insufficient Power
Existing internal doorbell not ringing correctly or Ring Video Doorbell works fine for a couple of events and then stops working.
Low Voltage
To solve this issue the Ring video doorbell may not be receiving sufficient voltage. For the Ring video doorbell to function properly it needs a minimum of 3,900 mV. You can check the voltage by opening the Ring app, selecting Ring Pro, and then selecting device health. If this does not fix the issue, you may need to replace the capacitor, which can be found on this link: https://support.ring.com/hc/en-us/articl...
Faulty Battery
If the Ring Video Doorbell is not turning on regardless if plugged in or not, then the battery may be defective. Replace the battery using this guide: Ring Doorbell 1st Generation Battery Replacement
Night Vision Malfunction
Poor video quality only at night or does not record at night time. System unresponsive only at night time.
Faulty Camera
If the camera is not responsive at all and no image can be seen, while everything else functions properly on the Ring Video Doorbell, the camera is most likely at fault. Thus, you will need to replace the camera, and the steps to do so can be found at this link:
Weak Internet Speed
Slow internet can cause problems with Live View. To see if this is the cause of the problem, test your internet speed. A minimum of 2 Mbps Upload and Download speed is recommended for the best streaming performance for Ring Pro and Floodlight Cam. Consider resetting your WiFi router if the problem persists. To do this, simply locate the reset button on the router, press and hold for 10 seconds.
Poor Wiring
Poor wiring may lead to video freezing and night vision issues, therefore, if you are experiencing any of these issues, check your wiring to make sure the Pro Power Kit is installed correctly using this guide: https://support.ring.com/hc/en-us/articl...
No Sound
Doorbell is not ringing or notifications cannot be heard.
Faulty Speakers
If the speaker is not responsive at all and no sound can be heard, even after ensuring audio is enabled from both the application and the Ring Doorbell, the speakers might need to be replaced. The following link will show you the steps to do this: Ring Video Doorbell Pro Speaker Replacement
Microphone Not Enabled
The microphone on the Ring Doorbell may not be enabled and therefore, you will not be able to receive and hear any sound. Therefore, ensure that the microphone has been enabled on the device, by going to the Ring Doorbell app and toggling the microphone button. If the issue persists you may need to replace the microphone. To do this, follow the following link: Ring Video Doorbell Quick Install Guide
Unresponsive Doorbell Button
No response from the doorbell when the ring button is pressed.
Stuck Button
If the button on the Doorbell is not responsive at all and does not ring or notify you on the application , even after ensuring audio and notifications are enabled from both the application and the Ring Doorbell, the button may need to be replaced. In order to do this, please follow the following link: https://support.ring.com/hc/en-us/articl...
Abdulrahman
crwdns2935283:002/20/18crwdne2935283:0
709 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G5, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G5, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G5
crwdns2944067:090crwdne2944067:0
One of our Ring door bells shows at ‘stripey red’ picture. Have checked the wi-fi signal is okay, and done device health (all okay) any ideas ?
ajton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This has been a pos since we bought it.
classact196805 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My ring door bell just crashes and will not connect to my phone no matter how many times I've tries to reset it, even the reset does not work
Andy t - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My ring doorbell 2 isn’t connecting to my router! Wtf I have done everything but a hard reset! C/S are a bunch of idiots they repeat everything that I tell them!! My problem is not resolved yet
mick brown - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have the ring 2 but my inside chime doesnt work. What do i do? i am running on battery power, do i need to buy another chime?
rochelle scott young - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 182
crwdns2959996:0crwdne2959996:0 301,042
