crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Power On
The device will not respond.
Faulty Battery
The battery might need to be replaced with a new one due to old age or internal reasons. Please look at our replacement guide for “Battery” to learn how to replace the battery pack.
Battery is not fully charged
The device is probably not turning on because the battery pack is not fully charged. Plug the battery into charger before using.
The drive gear is missing, loose, or needs to be replaced
The drive gear is the source of power for rotation if it is missing, loose, or broken it needs to be replaced for the drill to function normally. Check out our replacement guide for “drive gears.”
The multi- tool continues to run after the trigger is released
The drill does not stop after the trigger is released.
Trigger is stuck
There might be a problem with the switch trigger mechanism on the drill which causes the trigger to get stuck and not respond. To replace it please look at our replacement guide for “Switch Trigger” to see a step by step guide on how to replace the trigger.
Electrical problem
There might be an internal issue with the wiring. Pop open the drill and diagnose the problem. If the wire is loose simply put it back in place. However, if the wire is visibly damaged than please look at wire replacement guides provided by ifixit.
LED Light Won’t Turn On
When you press the button for the function, the light does not turn on.
LED burned out
The LED light probably was overused and so, the LED needs to be replaced. Please check out our replacement guide for “LED light” to understand the process.
The LED light is probably not working because the battery pack is not fully charged. Plug the battery into charger before using.
Device is Overheating
The device gets hot and unintentionally shuts off.
Faulty Battery
Dirty Motor
If the battery is not faulty, then the motor is probably dirty or worn-out. To learn how to replace a motor please look at replacement guides found on ifixit.com
Driver won’t change speed
The driver will not spin at the desired speed.
This function is probably not working because the battery is not fully charged. Plug the battery in overnight and it should work.
Trigger is stuck/broken
There might be a problem with the switch trigger mechanism on the drill which causes the trigger to get stuck and not respond. To replace it please check out our replacement guide for “Switch Trigger” to see a step by step guide on how to replace the trigger.
Pengjian Zhou
crwdns2935283:002/06/19crwdne2935283:0
557 crwdns2915208:0crwdne2915208:0
UC Davis, Team S20-G1, Lore Winter 2019 crwdns2935289:0UC Davis, Team S20-G1, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S20G1
crwdns2935297:048crwdne2935297:0
crwdns2944067:04crwdne2944067:0
Device works with different battery
Robert Lennon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Device keeps on rotating a Grout Stardock. should be on one spot.
David Chan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Device appears to have power but is not engaging the vibration motor. The LED on the tool (for illuminating the cut area) is blinking. No sound is on when trigger is depressed.
Nigel Wylie - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 5,465
