crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera will not power on
When the drive dial is turned into the "on" position there is no response from the camera
Battery is missing
Check if there is a battery. If there is a battery, try replacing it. If the replacement works, then the previous battery is defective.
Battery Replacement Guide
Shutter will not release
When the shutter is pressed there is no response from the camera and no pictures are taken
Batteries are running low
Shutter not releasing may occur due to low voltage. Is the battery mark blinking on the LCD panel? If it is, replace the batteries.
The film is not loaded correctly
Is "O" blinking on the exposure panel? If yes, open the back cover and reload the film.
Film Replacement Guide
Pictures appear blurry
The taken pictures are not clear, objects are not defined
Abrupt movement when the picture was taken
To prevent a blurry picture, steadily hold the camera and gently tap the Shutter Release button.
The AF monitor was blinking
This indicates the object is difficult to focus. Hold the shutter release button halfway and make sure that the AF monitor is lit and the object is focused before you press it completely.
Built in flash not responding
The flash does not light when the picture is taken
The lighting is not appropriate
If the flash is set to automatic, make sure the lighting in the room isn't too bright. If you can't do anything about the lighting, manually set the flash to "on" mode.
Infinity mode is turned on
The flash does not fire in Infinity mode. Turn the Infinity mode off and try again.
Zooming lens not working
The lens appears to be stuck and not adjusting or not focusing on the object
The camera was turned off improperly
This can cause the lens to get stuck in an undesired position. In this case, adjust the zoom manually and then turn the camera off by turning the switch into the "off" position.
The object is too close to the lens
The zooming lens requires the object to be at least 1 mt (3.3 ft) away from the camera when the Infinity mode is on and 2 mt (6.6 ft) away when the Panorama mode is on.
Film advance or rewind not functioning
The film will not rewind or advance when the camera is on
The batteries are running low
Film advancing and rewinding not working may be due to low voltage. Replace the batteries.
Self timer not functioning
The shutter does not release in the self timer mode
If the object is too close to the camera, the AF monitor will blink cancelling the self timer function. Back up from the camera and try again.
anna carolina von einem
crwdns2935283:010/19/16crwdne2935283:0
450 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 crwdns2935289:0UMass Dartmouth, Team 3-4, Isaacson Fall 2016crwdne2935289:0
UMASSD-ISAACSON-F16S3G4
crwdns2936753:030crwdne2936753:0 46
crwdns2959996:0crwdne2959996:0 1,793
