crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Digital Temperature Stopped Showing
The Remington Pearl Pro is supposed to show the temperature of how the straightener is, but when plugged in, it does not show the degree it is at.
The issue is possibly occurring due to a shortage in the wiring.
In order to complete the repair, unscrew the barrel of the straightener and fix the wiring.
Does Not Heat Up
When the straightener is plugged in, it does not properly heat up. It’s designed with a 30 second heat up that goes up to 450 degrees.
The cause of this issue is possibly due to a shortage in the wiring.
If does not heat properly, check the wiring in the platelets.
Shuts Off While Using
While the straightener is plugged in and in use, some people experience the product completely turn off.
To resolve this issue, the floating plates have to be removed. The swivel cord attached to the straightener will have to be removed and replaced.
Plates Stop Working
As you’re using the straightener, you may notice the plates are not getting hot at all.
This issue may be due to the plates being overused and worn out.
To resolve this issue, the floating plates will have to be removed and replaced.
Karxyriah Ashley
crwdns2935283:002/13/20crwdne2935283:0
58 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of North Texas, Team S2-G5, Thomas Spring 2020 crwdns2935289:0University of North Texas, Team S2-G5, Thomas Spring 2020crwdne2935289:0
UNT-THOMAS-S20S2G5
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 65
crwdns2959996:0crwdne2959996:0 1,494
