crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Razer Wolverine V3 Pro controller registers movement even when the analog stick is not touched, this page may have a solution.
Debris Interfering with Analog Stick Sensors
Dust or debris around the analog stick may interfere with the sensors.
  1. Power off the controller.
  2. Use compressed air to clean around the base of the stick.
  3. Gently move the stick in circular motions while cleaning.
  4. If necessary, lightly clean the area with isopropyl alcohol and a cotton swab to remove buildup.
  5. Let it dry completely before use.
Outdated Firmware
The controller requires constant updating for optimal performance.
  1. Connect the controller to a PC via USB.
  2. Launch the application ‘Firmware Updater’.
  3. Install the latest firmware update.
  4. Restart the controller after completion.
Improper Stick Calibration
The controller may be miscalibrated, causing it to register movement incorrectly.
  1. Connect the controller to a PC and use the Razer Synapse App or connect to your Xbox and use the Razer Controller Setup for Xbox App.
  2. Open controller settings.
  3. Locate calibration settings.
  4. Follow the on-screen steps to recalibrate the analog sticks.
Worn Analog Stick Potentiometer
If the analog stick continues drifting after cleaning and updating, the internal mechanism may be worn out.
  • Replacing the analog stick may restore its functionality.
  • If the potentiometer is worn out, the analog stick will need to be replaced.
Physical Damage to Analog Stick
Dropping the controller or applying excessive force can damage internal components.
  • Inspect stick for looseness or unusual resistance.
  • If the analog stick is damaged, it will need to be replaced.
Hidaya Nader Asad
crwdns2935283:002/15/26crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-2, Sneed Spring 2026 crwdns2935289:0University of Memphis, Team 3-2, Sneed Spring 2026crwdne2935289:0
UM-SNEED-S26S3G2
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 205
crwdns2959996:0crwdne2959996:0 787
