My Lyra Won't Turn on
When the power switch is turned on, the device displays no indication of functionality.
Battery Problems
Your problem may be battery related.
Drained Battery
Diagnosis:
To diagnose a discharged battery, simply plug your device into a 120v wall socket using the power adapter that came with it. If the charging light turns on, your battery may have been discharged.
Solution:
Try plugging your Lyra in for 20-30 min and attempt to turn the device on again.
Note: if the charging indicator light does not turn on while the device in plugged in, the problem may lie in either the power adapter, or the power plug in the side of the device. If this is the case, read this guide about how to safely remove the motherboard from the Lyra and install a new one.
Due to the rate of technological advancement and the discontinuation of the Lyra product line, replacement parts are extremely difficult to find.
Dead Battery
Diagnosis:
Even after attempts have been made to charge the device, the battery stays uncharged.
Solution:
If your device is still nonfunctional, try reading this guide about safely removing your battery for replacement.
Display Problems
Diagnosis:
Your Lyra may appear to be nonfunctional if the display has become disconnected or broken.
Solution:
If the display has been disconnected, it may be a simple matter of opening up the device and reconnecting the ribbon cable. If the display is truly nonfunctional, it may need to be replaced completely. In either case, read this guide about how to safely remove the display from your Lyra and (potentially) install a new one.
Screen protectors can be found here.
Motherboard Problems
Diagnosis:
If your device still will not turn on, you may have a problem with the motherboard.
Solution:
Read this guide for information on how to safely remove the motherboard from your Lyra and install a new one.
Warning: This is a complicated endeavor and has the potential to damage your device irreparably. Only undertake this solution if all other possibilities have been ruled out and proper precautions have been taken.
When I Try to Play Audio or Video Files, my Lyra Makes No Sound
When viewing audio or video media on the device, no sound can be heard from the built in speaker.
Volume Controls
Diagnosis:
You may have the volume on your Lyra turned down or muted. Many times this can be diagnosed by toggling the volume up/down button located on the side of your device.
Solution:
To fix this, review and adjust your volume settings using the onscreen system menu.
Diagnosis:
The motherboard in your Lyra may be broken or functioning incorrectly. If you have ruled out other solutions, this may be the issue.
Solution:
Read this guide about how to safely remove the motherboard from your Lyra for further investigation.
External Headphones/Speakers Problems
Diagnosis:
If you are using external headphones/speakers and this problem occurs, there may be a problem with the audio output on your device. If the sound functions correctly on your device when the headphones/speakers are not connected, but abruptly stops working when the headphones/speakers are plugged into the device, you may need to replace the audio output jack.
Solution:
Read this guide about how to safely remove the mother board in your device so the audio output jack can be replaced.
I Can't Record Sounds With my Lyra
When working with an application that requires use of the built in microphone, the recordings are either inaudible or unable to be understood.
Case Problems
Diagnosis:
It may be that the small opening in the plastic body of the Lyra for the microphone has become somehow obstructed. You may be able to see this by looking closely at the small hole in the top of the device labeled "mic."
Solution:
Read this guide about how to safely disassemble the case of the Lyra so it can be cleaned.
Microphone Problems
Diagnosis:
The actual microphone unit may have become detached from the mother board or in some way broken during use.
Solution:
Read this guide about how to safely access the mother board so the microphone can be replaced.
External Microphone Problems
Diagnosis:
If you are using an external microphone and this problem occurs, there may be a problem with the audio input on your device.
Solution:
Read this guide about how to safely remove the mother board in your device so the audio input jack can be replaced.
The Screen on my Lyra is Discolored
When the Lyra is turned on, the device experiences display problems.
Pixel Problems
The display shows one or more pixels of incorrect color or pixels that fail to turn on.
Dead Pixels
Diagnosis:
If one or more pixels on your display is black even when surrounding pixels are other colors, your display may have dead pixels.
Solution:
Read this guide for information about safely removing the display from your Lyra and installing a new one.
Cracked Display
Diagnosis:
If your Lyra has suffered a fall or other trauma, the display may have become cracked. If so, you may see a line of blurred discoloration across your screen.
Solution:
Read this guide about how to safely remove the display from your Lyra and install a new one.
Evan Lindquist
crwdns2935283:004/11/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-3, Regan Spring 2013 crwdns2935289:0Cal Poly, Team 17-3, Regan Spring 2013crwdne2935289:0
CPSU-REGAN-S13S17G3
crwdns2935297:096crwdne2935297:0
On my RCA tablet, my monitor cracked and im trying to see if there was a way to get my monitor replaced
TheUnchanted Sword - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 1,449
