crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Remote Won't Connect To The Drone
There is no connection between the remote and drone.
Batteries May Need Replacement
First, try to turn on the remote. The light on top should start blinking red and should make a beeping noise. If the light does not appear try switching out the batteries.
Improper Antenna Alignment
The next thing to check are the two antenna on top of the remote. Make sure they are in the upright position and properly rotated. Have the antenna facing the drone during take off as well as flight.
Low Drone Battery Power
Check the drone battery to make sure the device is charged. If it is not then there is now way that there will be a connection between the remote and drone. After the battery has completed its charging make sure that it is fully inserted into the back of the drone. When the drone is turned on, you should see a combination of red and green flashing lights. This will indicate that the drone is charged and ready for use
The Drone Is Flying Sideways
The drone isn't going straight.
So it seems that your drone wont fly straight. This could be caused by the weight of the drone being uneven. The first thing to make sure of, is that all of the blade guards are attached. Missing one of them would be the most logical problem for it flying sideways. The next thing to look at is the connectivity between the drone and the Wi-Fi signal to make sure there is adequate signal strength for the drone to connect to.
Blades Guards Come Off
The little blue guards fell off.
Improper Attachment of Guards
This is the simple problem to fix. The blade guard more than likely came off due to a crash or collision with something during flight. When reattaching the guards you should take care to find both of the clips and firmly press the guard into place. You will hear 2 clicks and these clicks will let you know that the guard is fully attached and ready for use.
Drone Flew Away And Dropped
The drone does not respond while flying.
Battery Not Charged
If the device is unresponsive first check if the battery is fully charged and properly connected. If the battery is inserted correctly then the next step would be to check the WI-FI signal.
Poor Wi-Fi connectivity
If you are having a weak signal you might be to far away from the drone. Try moving closer to the drone and see if the signal strength increases. If that does not work restart the drone and try again. After trying those two steps the final option is to turn the connection off and back to see if the issue resolves itself.
Drone Won't Turn Off
The drone stays on all the time.
Battery Connection
If the drone is staying on all the time the first thing you want to check is that the battery is fully removed form the drone. If the drone blades start to spin before the remote has been switched into the one position then will need to check the connection that is made between the battery and the prongs inside of the battery slot itself.
Faulty Remote Battery
If the batteries in the controller are missing or not installed properly, the controller will not receive power.
To install batteries into controller
Remove controller battery compartment cover by sliding it down. Remove the batteries from the compartment. Then insert four (4) 'AA' batteries in the correct orientation. Finally, install the controller battery compartment cover.
Drone Battery isn't Working
Make sure the battery pack is plugged into the drone correctly and the battery pack is fully charged using the power cord provided.
WIFI Signal
Antenna placement is critical for signal strength. A straight placement of the antenna without objects in the path is important for good signal strength.
Kayla Brown
crwdns2935283:003/22/18crwdne2935283:0
491 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S17-G5, Blackburne Spring 2018 crwdns2935289:0Sam Houston State, Team S17-G5, Blackburne Spring 2018crwdne2935289:0
SHSU-BLACKBURNE-S18S17G5
crwdns2944067:05crwdne2944067:0
Hi,
My Drone is not connecting to my Remote, I have tried everything you have written above however it still isn’t connecting. My only guess is that we accidentally changed the channel of the drone or the remote because everything is working fully functional when I use the Dura VR app. Any help is appreciated, thanks!
yakrebb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello,
So when I try to start the engine the propellers spin for about 2 seconds then stop and the lights start to flash, then when I click the take off button it goes into the air for about a ft then drops
Majin Rivera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine did same thing. I removed all propellers and tried to take off. I touched each one if the spinning motors and discovered when I touched one of the motors out would then die. That motor was failing, now I am in search of spare motors for these dura hd drones. No. Luck so far
chrisweg1974 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can not download the dura vr app with my Android cell phone. Can anyone help?
Sherry Parton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I view a video I recorded, it is just a green screen.
Maxbighead06 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 44
crwdns2959996:0crwdne2959996:0 1,923
