What screwdriver do I need to open, upgrade, and repair my PS5?
The PlayStation 5 can be opened without the use of any tools—the white panels pop off with a gentle tug, allowing immediate access to the m.2 SSD expansion slot, the fan, and vacuumable dust ports.
crwdns2944684:0crwdne2944684:0
Always follow iFixit’s screwdriver best practices to avoid stripping screws. In general, use the largest driver size that fits snugly into the screw to avoid stripping the screw.
Standard Torx (Won’t fit PS5 fan screws)Security Torx (Will fit PS5 fan screws)
The tip of the Torx Security (we refer to it as a TR#) screw head has a small hole in the center which differs from a standard Torx screw head (referred to as a T#).
crwdns2944682:0crwdne2944682:0
You can bypass these security screws with nothing but a small flathead screwdriver. You can decide how you want to tackle these security screws but do not listen to a random Redditor that tells you to "use a Phillips and really get in there" unless you want to strip the screws on the outside of the case.
What screwdriver do I need to open, repair, and mod my DualSense controller?
You’ll need a small Phillips screwdriver to remove the 4 screws that secure the controller. Two of the screws are hidden underneath the L1 and R1 buttons so you will need to pry those off to access the screws. The other two screws are located underneath the controller's removable black trim.
Two screws securing the bottom corners of the lower caseTwo screws behind the L1 and R1 buttons
crwdns2916044:0crwdne2916044:0
The number of screws that secure the adaptive trigger mechanism housings (not pictured above) differ based on the DualSense version number. We have a resource for identifying your controller's version number.
What other tools will I need?
Spudger
A spudger is a versatile tool perfect for removing the L1 and R1 buttons to access the screws on the DualSense controller. This tool is also suitable for removing the grill away from the console when replacing the fan.
Precision tweezers work at removing small hard-to-reach parts in the DualSense controller and moving the spacer to the appropriate slot when replacing the SSD in the console.
Opening Picks
Opening picks are useful for prying open controllers that are held together with clips. Insert an opening pick underneath the middle trim to release the clips securing it to the case of the DualSense controller.
Evan Gattuso
crwdns2935283:009/13/21crwdne2935283:0
22.408 crwdns2915208:0crwdne2915208:0
Staff
crwdns2935297:072.611crwdne2935297:0
What is the actual size of the shell screws as in M 2.5 x 10mm? Just as an example.
Richard Renfro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i find replacement for missing screws of a ps5 slim, also is there a schematic of where they goes?
David Boisvert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 90
crwdns2936753:07crwdne2936753:0 489
crwdns2936753:030crwdne2936753:0 2,404
crwdns2942667:0crwdne2942667:0 54,912
