crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Smart PIPO S1 Tablet won’t turn on:
You can’t get your tablet to turn on
Charge the device
The battery of the device may have been out of charge, Try recharging it before doing any other action.
Dead Battery
The battery of the device may be dead and cannot be recharged. You have to replace the battery by following the battery replacement guide instructions.
Bad Display Screen
The display screen is the reason you can’t turn on the device and it doesn’t look like working. Follow the guide instructions to replace the display screen.
The camera is not working
The camera is not working and you can’t take videos or pictures.
Restart the device
The camera freeze and is not responding to the commands. Try restarting your device before doing any other action.
Replace the camera
The camera needs to be replaced. Follow the guide instructions to replace the camera.
The device is not charging
You can’t get your device to charge.
Make sure the charger is connected properly to the device
The charger insert may be not pushed all the way in, something might be stuck inside try to clean the charging port.
Make sure the charger is original
Chargers that are not genuine may provide different voltage and current and the device is programmed to receive certain rand of volts and amps due to safety to protect the internal components from burning and or exploding. Use only certified original chargers even if you are not having charging issues.
Replace the charging port
The connector might be eroded due to age or friction so try a new charger.
Tablet cannot connect to Wi-Fi
The tablet is not connecting to the Wi-Fi router.
Make sure Wi-Fi module is open in settings
The Wi-Fi may be turned off in the mode setting. Turn on the Wi-Fi n order to connect to the Wi-Fi router.
Replace Wi-Fi antenna
The Wi-Fi antenna may be damaged. Replace the Wi-Fi antenna by following the guide instructions.
The screen is still dark after unlock
You can’t see anything but black screen when you think your device is turned on.
Start by checking the brightness setting
Sometimes you adjust the brightness to low earlier specially at night and forget about it and that would cause a dark screen in the morning.
The software and the screen may not be debugged well
There are some software that are not compliant with screen output and resolutions, and that might be causing your problem, so quit the program and check if the screen come back to normal.
Your LCD may be not original
Screens that are not original can be of poor quality and thus may become defective by internal shortcut. If that is the case, replace it with an original LCD screen.
Your LCD may have been damaged
Your device may have fallen earlier and become damaged and that’s cause it not to display anything. Replace your broken screen with an original LCD screen.
The capacitor on FPC screen or on screen display circuit on the motherboard may be defective. Although it is rare it can happen, you need to open the device and replace the capacitor with the matching capacitor.
Ahmed AlQallaf
crwdns2935283:010/14/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 3-6, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 3-6, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S3G6
crwdns2935297:036crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,301
