crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
When pressing the “on” button on your Philips Somneo alarm, it is not reacting by turning on. Please follow the steps provided below to fix the issue.
Not Connected to power
The Philips Somneo is not a wireless device, meaning it comes with a plug in the back. Check to see whether or not your device is plugged into a a working outlet. If the device is plugged in then please try method 2 below.
Device is Frozen
In order to perform a hard reset, the reset button can be found behind the device. When the reset button is located, use a small tool to press the small reset button and hold for a couple of seconds. If the device is hard reset and still is not turning on then please try method 3 below.
Power Supply is Damaged
If the previous solutions have not addressed the problem, you need to replace the power supply, please see the placement guide linked here
Isaiah
crwdns2935283:003/21/25crwdne2935283:0
332 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-1, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 6-1, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S6G1
crwdns2942667:0crwdne2942667:0 251
