crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Ozeino OW810 microphone not pikcing up sound? Use this troubleshooting guide to help diagnose why.
Bluetooth Switch Needs to be on
If your headset is turned on and the sound is working, try ensuring that the power is on for the Bluetooth microphone.
  • The Bluetooth connection button is on the right side of the headset, press and hold this button until the set lights up.
  • Make sure you have the chip plugged into the device you are using.
Disconnect and reconnect from your desktop or device
Depending on what device you are connected to, try restarting your device and see if that helps the issue.
  • Try restarting your device and disconnecting Bluetooth from the device.
  • Another tip is to turn the headset itself off and then back on if you are experiencing connection problems
Jackson H. Jones
crwdns2935283:003/05/25crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-6, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-6, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G6
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 2,278
