crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Oral-B IO Series 6 toothbrush's display looks dim, review the solutions below to fix it.
Faulty Battery Connection
Vibration and use of the brush may adjust or shift the battery in a way that disrupts its connection to the board. Open the brush and pull off the outer casing. Remove the battery and firmly press it back into its holding.
Faulty Battery
Like all batteries, they lose their power over time. Open the brush and pull off the outer casing. Remove the current battery and replace with a new one.
Interior Moisture
The waterproofing of the toothbrush internals is not perfect and some moisture can build up on the inside. This moisture can collect on the plastic interior of the case, where the display shines through, or even on the display screen itself. Open up the brush and pull off the exterior casing. Place the separated components in a dry location and allow to dry. When reassembling, ensure that all seals are properly sealed and that there are no cracks or holes in the casing.
Michael Cardinal
crwdns2935283:003/21/25crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 1-7, Rioux Spring 2025 crwdns2935289:0UMass Dartmouth, Team 1-7, Rioux Spring 2025crwdne2935289:0
UMASSD-RIOUX-S25S1G7
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 566
