Optical Drive Types
There are several types of optical drives available. Some can use only CDs, which typically store about 700 MB of data. Other optical drives can use DVDs, which typically store 4,700 MB to 8,500 MB of data. CD-ROM drives and DVD-ROM drives are read-only (the "ROM" part of the name). CD writers and DVD writers (also called burners or recorders) can write optical discs as well as read them. DVD is backward-compatible with CD, which means that a DVD drive can also read CD discs, and nearly all DVD writers can also write CD discs.
Roughly in order of increasing price and usefulness, the choices are:
CD-ROM drive
When price is the absolute priority, installing a CD-ROM drive provides basic functionality at minimum cost. CD-ROM drives read only CD-DA (audio) discs, CD-ROM (data) discs, and (usually) CD-R/CD-RW writable discs. CD-ROM drives are commodity items that sell for $15. In fact, manufacturers make so little profit from CD-ROM drives that they have all but disappeared from retail channels. The sole advantage of a CD-ROM drive is its low price. The drawbacks of a CD-ROM drive are that it cannot read DVD-Video, DVD-Audio, or DVD-ROM discs and that it cannot write discs. Choose a CD-ROM drive only as an inexpensive replacement for a failed optical drive on an older system that does not require DVD support or recording features. CD-ROM drive choices are limited and likely to become more so as these drives disappear from the market. We consider any current ATAPI model made by Lite-On, Mitsumi, NEC, Samsung, or Sony acceptable. All are reliable, so buy on price. Unless the small extra cost is a deal-breaker, we strongly suggest installing a more capable optical drive.
DVD-ROM drive
DVD-ROM drives are also commodities, but cost a bit more than CD-ROM drives: $20 or so. Like CD-ROM drives, DVD-ROM drives read CD-DA, CD-ROM, and CD-R/RW discs, but they also read DVD-Video, DVD-ROM, and (sometimes) DVD-Audio discs. Even if you're repairing or upgrading on a tight budget, it usually makes sense to spend an extra $5 to get a DVD-ROM drive rather than a CD-ROM drive so the PC can read DVD-Video and DVD-ROM discs. Like CD-ROM drives, DVD-ROM drives are read-only devices, and cannot write discs. Nearly all current DVD-ROM drives read CDs at 40X or 48X and DVDs at 16X with similar access times and otherwise similar specifications, so there is little reason to choose a brand other than by price and manufacturer reputation. We consider any current ATAPI model made by Lite-On, Mitsumi, NEC, Samsung, Sony, or Toshiba acceptable.
CD-RW drive
CD-RW drives, also called CD writers, CD burners, or CD recorders, sell for $25 or so. CD writers read the same formats as CD-ROM drives CD-DA, CD-ROM, and CD-R/RW discs but can also write data to inexpensive CD-R (write-once) and CD-RW (rewritable) discs. Although CD-RW drives do not read DVD discs, they have the advantage of being able to write discs. In addition to being useful for duping audio and data CDs, CD writers also provide an inexpensive backup solution, albeit limited to about 700 MB per disc. Nearly all current CD-RW drives write CDs at 48X, 52X, or 54X and have similar read speeds, access times, and other specifications, so there is little reason to choose a brand other than by price and manufacturer reputation. We consider any current ATAPI model made by Lite-On, Mitsumi, Samsung, or Sony acceptable.
DVD-ROM/CD-RW drive
Combo drives combine the functionality of a DVD-ROM drive and a CD-RW drive, and typically sell for $30 to $35. Because they can read nearly any optical disc and write CDs, combo drives were quite popular until the price of DVD writers dropped. At current prices, we'd consider using a combo drive to replace a failed optical drive on an elderly system or in situations where the additional $5 to $40 cost of a DVD writer can't be justified. We consider any current ATAPI model made by Lite-On, Samsung, Teac, or Toshiba acceptable. If you need to read burned DVDs, make sure that the model you choose explicitly lists compatibility with the formats you use. If you need to read DVD-RAM discs, buy a Toshiba model. Otherwise, all are reliable and priced similarly, so buy whatever happens to be the least expensive.
DVD writer
DVD writers do it all they both read and write both CDs and DVDs. That flexibility used to come at a high price, but current DVD writers are available for as little as $40 and even the best internal models sell for $100 or less. Here are the issues to consider in choosing a DVD writer:
DVD writable formats supported
All current DVD writers can write DVD+R, DVD+RW, DVD-R, and DVD-RW discs interchangeably. Most models can also write dual-layer DVD+R DL and/or DVD-R DL discs which store about 8.5 GB rather than the 4.7 GB capacity of standard single-layer discs although the least-expensive models may not support writing DL discs at full speed. A few drives remain available that support the moribund DVD-RAM standard.
CD writing capabilities
Many people use DVD writers primarily for writing DVDs, and seldom or never write CDs. However, the CD-writing features and performance of a drive are important if you frequently use CD-R or CD-RW discs, perhaps to duplicate your audio CDs or for daily backups. If CD writing is important to you, make sure the drive you buy supports at least 40X CD-R writes and, if you use CD-RW, 24X CD-RW rewrites. Also make sure the drive supports BURN-Proof or a similar anti-coaster technology.
Write speed
Early DVD writers recorded discs at only 1X. As was true of CD writers before them, rapid product development soon boosted the speed of even low-end DVD writers to the maximum practical write speeds for the various formats. In the case of writable DVD, that's 16X for single-layer R discs, 8X for DVD+RW and DVD+R DL, and 4X for DVD-RW and DVD-R DL.
If you have an older DVD writer and you write many DVDs, upgrading to a faster current model is probably worth the small cost. Using a 4X DVD writer requires patience; it takes 15 minutes to write a full disc. An 8X writer cuts that to 8 minutes or so, and a 16X writer to about 4.5 minutes. (In each case, the writing speed actually doubles, but writing the table of contents and closing the disc requires a minute or so regardless of writer speed.) Note, however, that for various reasons you may not always write discs at the maximum rated speed of the drive. For example, we often use 8X discs in our 16X writers, because the 8X discs are both less expensive and more reliable. Similarly, when we record video to 8X DVD+R discs, we write them at only 2X or 4X, because discs written at 8X, 12X, or 16X are often rejected by our DVD player or exhibit video and audio artifacts.
Interface
Nearly all internal DVD burners use the standard ATA/ATAPI interface. A few models notably some Plextor drives are available in Serial ATA. We suggest you avoid SATA models. The drives themselves are fine, and there's nothing wrong with the SATA interface, but using an SATA optical drive introduces numerous compatibility issues. Very few motherboards, even newer models with full SATA support, work properly with SATA optical drives. Even if the motherboard supports the drive properly, you may find that your operating system and applications don't recognize an SATA optical drive.
Internal versus external
For most systems, an internal ATA/ATAPI DVD burner is the best and most economical choice. However, DVD burners are also available in external variants that connect to a PC using the USB 2.0 and/or FireWire interfaces. Although external drives are more expensive than internal models, they do have a couple of advantages. First, you can share an external drive among several systems, for example for doing periodic backups. Second, an external drive can be used with a notebook computer or other system that doesn't permit installing an internal drive. If an external drive is right for your needs, choosing a model that provides both USB 2.0 and FireWire interfaces offers the most flexibility.
Plextor makes the best DVD writers available. They sell at a premium, but we consider their small additional cost worth paying for their superior reliability and the high quality of the discs they write. The Plextor PX-716A, their flagship model, is superb. It has every imaginable feature, top-notch performance, and is built like a tank. The Plextor PX-740A, their economy model, has a smaller buffer and fewer features, but is built to Plextor's usual high standards. For an external DVD writer, we recommend the Plextor PX-716UF, which provides both USB 2.0 and FireWire interfaces.
If you're on a tight budget, a Plextor model may be out of your price range. In that case, we recommend the NEC ND-3550A or the BenQ DW1640.
Unless you're counting pennies, we strongly recommend choosing a DVD writer rather than a less capable optical drive. Other than the SATA issue, you needn't worry about compatibility. Modern DVD writers function properly even in older systems.
More about Optical Drives
crwdns2935291:0crwdne2935291:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,968 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,966crwdne2935297:0
crwdns2944067:04crwdne2944067:0
i like what it talks about in the paragraph at the top of the screen.
Taylor Rogers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What do you mean SATA optical drives aren’t recognized by the majority of motherboard SATA interfaces? That’s about the only interface there is anymore?
Robert B Seward Jr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 134
crwdns2959996:0crwdne2959996:0 54,260
