crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Cannot take, edit, or delete photos on a SD Card
Switch on SD Card
SC Cards have a switch on the side that can lock the card.
Make sure that this switch is not in the "Locked" position.
Reset Camera
Remove the battery and keep it removed for 8 hrs.
Software Protection Enabled
Follow the "Canceling all protections" section of the Owner's Manual, Pg. 66
SD Card Formatted improperly
Reformatting the Card in another camera or computer may fix the issue.
There may be corrupt files on the card which are causing issues with the camera.
Owner's Manual Pg. 95
Camera has a very slow auto-focus.
This issue could be caused by having out of date firmware or the size of the default auto-focus box is to large.
Reducing the size of the auto-focus box.
1. From the normal shooting screen, press the "zoom" button.
2. Press the "info" button once. 7x will be displayed in the bottom left corner.
3. Press the "up" button once, 10x will be in the bottom left corner and the auto-focus box gets smaller, press again you get 14x the auto focus box gets smaller.
4. Press "ok" once, now you can move the box around using the keypad.
After the camera powers down the auto-focus box will return to normal size, press the zoom button to use the small box again.
Update the Firmware
Before Updating
1. Scroll through the camera's menu, and select the firmware option.
2. Check the firmware version. If it is not 1.3, then it should be updated.
Updating
1. Plug in a newly charged battery.
2. Remove the SD card.
3. Click here
4. Download the Olympus Digital Camera Updater, and follow the instruction that come with the download.
Camera Freezes When I Take a Picture or Refuses to Take a Picture
Check the battery, reset the camera, and make sure that the shutter is
not stuck. If the shutter is stuck, clean it and apply lubrication.
Camera Turns Itself Off and LCD Screen Turns Black
This issue most commonly happens after a sharp impact such as a drop. The most common causes are an out of alignment shutter, stuck shutter, broken shutter pin, or a faulty main board.
Device Page
Here
Jeffery Smith
crwdns2935283:003/11/15crwdne2935283:0
831 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 9-1, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 9-1, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S9G1
I have an Olympus 500 digital camera. I removed the memory card and when I put it back in a message came up saying CARD ERROR. How do I fix it
Kay Bestwick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have Olympus pen EPL 1s. The lcd screen has darkened by all sides. Should I have to replace it entirely or parts. I'm unable to find any professional in Kolkata,West Bengal,India. Please help
subhrajyoti das - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My olympus e-pl1 has a huge problem. Randomly it switches modes from auto to P or art or smth.
Vid - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 99
crwdns2959996:0crwdne2959996:0 8,806
