crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unresponsive Touchscreen
Phone does not respond to touch gestures
Foreign Elements on Screen
Ensure that the touchscreen is free of dust, oil or water. If it is, use a soft cloth to clean your device’s screen careful not to scratch the screen.
Mild Software Malfunction
If the screen is still unresponsive after a wipe down, consider restarting the phone. Allow the phone to be off for one minute before powering it back on.
Audio is Distorted
Nokia 6 audio doesn’t play properly
Faulty Speakers/Headphones
This might be unlikely, but it usually is the easiest to problem to eliminate. Try your Nokia 6 with different sets of speakers and headphones to make sure that the problem is phone, not the external devices.
DOLBY Surround Software Malfunction
In some newer phones, the phone’s system update causes the DOLBY Surround Sound to not function as intended. To fix the issue, turn off DOLBY Surround Sound. To turn this off, go to Settings, select Sound, select DOLBY Surround Sound, then toggle the ON/OFF switch. Finally, perform a hard reset on the phone.
Fingerprint Scanner Unresponsive
The phone does not unlock when you place your finger on the fingerprint scanner
Foreign Elements on Scanner
Ensure that the fingerprint scanner is free of oil and dust. Since this is the touched every time you unlock the phone, it’s more likely to have dirt on it.
Foreign Elements on Finger
Wash your hands to make sure that there is nothing preventing your fingerprint from being read. If this does not work, reset the fingerprint presets under settings. You can do this by navigating into Settings, then selecting Security, and finally Fingerprint.
SD Card Not Detected
The SD Card is not detected by your device
Mild Hardware Problem
The solution may be as simple as taking out the SD Card and putting it back into the slot. The SD card slot is located on the left side of the phone. Eject the SD card and wait 30 seconds before reinstalling the SD Card.
Software Problem
If reinserting the SD Card does not fix the problem, try turning off the device for at least 60 seconds and powering it back on. A combination of the two may be required, meaning the SD Card needs to be removed, the phone powered off, then back on, and the SD Card reinserted.
Foreign Elements on SD Card or SD Card Slot
If neither of the above work, try gently cleaning off both the SD Card and the SD Card Slot with a cloth or compressed air before inserting the SD Card.
Phone is Overheating
The phone becomes really hot after extended use
Application Using Too Much Energy
An application on your phone might be too much for the phone to handle. Highly graphical video games or large applications would warm up the phone after extended use. Consider taking a break from the game or opening the applications one at a time while using them.
Poor Charging Cable
This might be because you are not using the original charging cable. Consider purchasing the original cable if the phone is overheating while charging and you do not own it.
Old or Overused Battery
If the phone is still overheating after following the previous troubleshooting steps, it might be due to having an old battery. If this is the case, consider installing an app to control your phone’s temperature. If this still continues, replace the battery as soon as possible.
References
https://www.technobezz.com/common-nokia-...
https://mobileinternist.com/nokia-6-bugs
Minh Tran
crwdns2935283:004/15/19crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team S9-G15, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S9-G15, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S9G15
crwdns2935297:0120crwdne2935297:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 2,915
