The Nokia 6230b is a phone released in North America. Common problems exist in the device, such as:
Phone Doesn't Turn On
Power Button Jammed
The red power/end call button may stick so it will not depress correctly.
  1. Using a small pair of tweezers gently take a hold of it and pull upwards.
  2. If button won't unjam remove the front cover and replace the keypad.
Faulty Battery Connection
Verify there is not a bad connection between the battery and the phone.
  1. Remove the back cover and remove the battery from the phone.
  2. Verify there is no dirt on the battery and connections.
  3. Wipe gently with dry cloth if necessary. An eraser or file may be used for hard to remove dirt.
  4. Replace battery and turn on.
Battery Replacing
If the previous steps have not succeeded replace the battery.
  2. Follow the steps to remove the multimedia card in order to find and view your model number. Use the model number to order a new battery.
  3. Insert the new battery into the phone and charge before turning on.
Phone Doesn't Make Sound
Ringer Volume is Too Low
Use the arrow buttons on the side of the phone to increase the ringer volume.
Phone Settings Are Set to Silent
Verify settings within the phone's menu are not making sounds inaudible.
  1. Select Menu > Settings > Profiles. Select a profile other than silent.
  2. Select Menu > Settings > Tone Settings. Increase tone volumes.
  3. Select Menu > Settings > Call Settings. Increase speaker volume during a call.
Speaker is Broken
If phone is not set on silent, ringer volumes are turned up, and no sound can be heard replace the phone's speaker.
Broken Display
Cracked Screen
A cracked screen will need to be replaced.
Undamaged Screen
  1. Try restarting the phone.
  2. Check the connections between the screen and the motherboard.
  3. If the connections between the screen and the motherboard are intact, the LCD screen may need to be replaced.
Phone Not Responding to Keypad Commands
Keypad is Dirty
Remove the keypad and gently clean
Broken Keypad
If cleaning does not work, replace the keypad.
Broken Motherboard
If keypad is clean and intact replace the motherboard.
Phone Won't Take Photos
Jammed Camera Button
Verify the button used to take photos is not jammed or stuck. Use tweezers to pull it out if it is jammed. If this does not work replace the keypad.
Broken Camera
If keypad is intact try replacing the camera.
Christopher McKee
crwdns2935283:010/04/10crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-27, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 3-27, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S3G27
crwdns2935297:0108crwdne2935297:0
crwdns2959996:0crwdne2959996:0 2,949
