Flashlight won't turn on.
Flashlight will not turn on even after sliding the switch.
Power switch is not working.
Check if switch is jammed or removed. If switch is damaged the flashlight will not function. If the switch is functional, continue reading.
Battery is faulty.
The battery provided could be faulty, try operating flashlight after replacing with a new rechargeable battery. If flashlight still won't turn on, continue to next step.
Corrosion exists on the battery contacts.
Corrosion sometimes appears on the springs and contacts of the battery container. Corrosion can be treated and cleaned with vinegar and an old toothbrush.
Battery is not charging.
Battery will not hold a charge.
Use a battery checker or voltmeter to check if the AA battery is outputting the 1.2V it is rated for, if it is outputting less than 75% of rated value, it is time to change the battery.
There could be a disconnected wire between the solar panel and the battery preventing it from charging.
Check for corrosion on the battery contacts.
Light from flashlight is dim.
Faulty light bulbs.
Check if all three light bulbs in the device are bright and uniform. If the bulbs are not uniform they may need to be replaced.
Low voltage battery.
When rechargeable batteries have been charged and discharged multiple times, they begin to wear and become weak.
If a battery is worn, the light could be dimmer than if you have a full strong battery. Try replacing the battery with a new battery and check the bulbs again.
Kasey Kolyno
crwdns2935283:001/20/15crwdne2935283:0
125 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 19-2, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 19-2, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S19G2
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 826
