crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Blender Will Not Power On
The blender will not respond or show any signs of powering up.
Faulty Outlet Connection
The problem may not be with your blender; it may be with the power source. Try pressing the red button on the outlet. This will reset the outlet and fix any faulty connections. WARNING: Unplug your device before pressing. Use caution when working around outlets.
Power Button Won't Stop Blinking
The blender seems to have power but the power light is flashing.
Blender is not Properly Assembled
The blade column may not be locked in to the bottom of the blender. Try taking the column out and reinserting it. Also, check to see if the lid is secure. If not, take it off and put it back on, locking it into place. Finally, the blender may not be fully secured to the base; unlock the blender, and then try to put it back into place.
Blender is Overheated
Turn off your blender, unplug it, and let it sit for 15-20 minutes. This will allow for your blender to cool down. Many factors can lead to overheating, including repeated usage or leaving the blender plugged in for too long. Try powering on the blender after the allotted time to see if the problem is fixed.
Blender Blades Will Not Rotate
The blender does not rotate when the button is pushed.
Blender is Overfilled
The Ninja NJ600 series blender only functions properly up to a certain capacity. Remove some of the contents from your blender and try blending again.
Blender is too Loud
The blender seems to be extremely noisy.
Check if the blade column is aligned properly to the base of the blender. If this does not solve the problem, then check that the lid is sealed on tight. If neither of these correct the issue, unplug the blender and let it rest for 10-15 minutes. The blender may be too hot, which will cause more noise. Letting it cool down should solve the issue.
Improper Setting
You should avoid using the highest setting (power setting 3) on contents that do not require high-powered blending. If you do this, the blender might seem louder than normal. Try a lower setting and see if the noise is under control.
Blender is not Blending Food Properly
The blender is not chopping food to the desired consistency.
Blender is Over Capacity
Try to blend less food to make it easier for your blender. The Ninja NJ600 blender is only designed to blend a certain amount of food. If this capacity is exceeded, not all of the food will be able to be blended properly. Remove some food and try blending again.
Food is Overprocessed
First of all, you may have added too much liquid to the blender. Remove some of this liquid and try blending again. If no liquid was added, you may have cut your ingredients too finely. This could be giving your food an overprocessed, liquid consistency. Use larger chunks of food and try blending again.
Nathan Delaney
crwdns2935283:004/01/15crwdne2935283:0
177 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-2, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-2, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G2
crwdns2935297:069crwdne2935297:0
crwdns2944067:022crwdne2944067:0
My blender blades turn a couple of times then it stops turning and the on light goes out. What is wrong with my Kitchen System 1100?
Dorothy Legg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My blender blades turn when in water or liquid but stop turning when under a light load (i.e. when it has chunks of vegetables, fruit or ice cubes in the blender jar). What is the problem or repair required to my Ninja Kitchen Pro System 1100?
Bruce Rice - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need help..blender was used a few times...Tried to use it to mix drinks and it would not blend..The power light just blinks, no blending of any kind....This thing is not that old..I received it as a gift.......What am i to do????? LINDO@ZOOMTOWN.COM
lindo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having the same problem as Lindo & Kathleen McPherson, when I hit the power button it just blinks and will not come on. Does anyone know what causes this problem?
Frank Rebarber - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
took apart and found power button on circuit board had fluid that got into it . it would not power up any more . I dried up the moisture in and around the button with a can of pressurized air used for electronic things and reassembled and it was a fix!
dennis heistand - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 30,614
