crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Coffee Maker Would Not Turn Off
I can not find the on/off button.
There Is No Off Button On CF080 Series
There is no power button on the machine. By manufacturer default, it would self turn off after a couple of minutes.
The Brew Basket Is Not In Right Position
When the brew basket comes out, how do I put it back in?
Remove and Insert Brew Basket Again
To remove the brew basket from the brewer, pull it straight towards, and boost the brew basket at a slight angle.
To re-insert, align the brew basket with the rails in a straight line and slide it back into the brewer until it clicks into place.
Coffee Bar Is Beeping
My coffee bar is beeping and it is not working.
Fill Reservoir Tank
Check your reservoir tank. Your Ninja Coffee Bar needs appropriate amount of water to work.
Check Brew Basket
Your Ninja Coffee Bar can not work if the brew basket is not inserted all the way into the brewer.
Check Drip Stop
Your Ninja Coffee Bar can not work if the drip stop is closed.
Run Clean Cycle
If your Ninja Coffee Bar is still beeping, it may be time to run the Clean cycle. Please refer to the "How to clean & descale your Ninja Coffee Bar" FAQ by the manufacturer.
The "CLEAN" Notification Never Turns Off
The clean light never turns off even when you've done.
Press Clean Button Again
Fill the reservoir with clean water and press the clean button again. It just flushes water through (does not run a whole clean cycle again) and the light goes off after the flush.
Water Reservoir Is Leaking
My Coffee Bar is leaking after a fill the water.
Too Much Water in Reservoir Tank
Your Ninja Coffee Bar is designed to use only a specific amount of water. So only fill the water up to, but not exceeding, the Max Fill line.
Jan Chen
crwdns2935283:009/11/17crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S1-G1, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S1-G1, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S1G1
crwdns2944067:063crwdne2944067:0
None of these things help make my pot work! It beeps after 30 secs of turning on. The reservoir leaks, and I don’t overfill it. It shuts off for no apparent reason!! Getting pretty feb up with this ninja coffee bar!!
Sharon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine is doing the same thing. It worked perfectly, then it cuts off after a few seconds. I tried to clean it, but it won’t stay on long enough to do anything. Any suggestions?
Terri Plyler - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Having the same problem. Did anything work for you?
merosharro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Ninja does the same thing. Cuts off after a few seconds of cutting on. It won’t stay on long enough to even try to clean it. Any suggestions?
crwdns2936753:030crwdne2936753:0 43
crwdns2959996:0crwdne2959996:0 37,851
