crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Won’t Turn On
Green Light of Death
“The green light on the back of the camera flashes and the rest of the device does not appear to power on.”
The “Green Light of Death” occurs in many Nikon cameras. A good forum post explaining several solutions can be read about here.
Camera Won’t Turn Off
Faulty Battery
Remove the battery and let sit for about 5 minutes or more.
Images Are Poor Quality
Focus Issues
“The camera will not focus or focuses slowly.”
Adjust Auto Focus Settings
If the camera is back focusing or not focusing on the intended object, the auto focus setting might be turned off. Adjust the auto focus using this guide.
Reset To Factory Settings
If the previous guide does not fix the problem other settings may be altered. To reset the camera to its factory settings, use this guide.
Camera Does Not Save Photos
“SD card not properly functioning”
Nikon D7100 not recognizing when a SD card is inserted. To fix this issue remove the battery and SD card. Then turn and hold the power knob to the light bulb position for 15-30 seconds. Finally reinstall the SD card and battery and turn the camera back on.
Zachary Detota
crwdns2935283:002/20/18crwdne2935283:0
405 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team S11-G6, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G6, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G6
Camera shuts down suddenly with no sign of battery low, even on full battery and when it shuts off the shutter doesn’t close, need to charge a the battery for it to work but it’ll shut down again after a short period of time
MAXEYE MATRIX founder - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, my camera lighting burns photo after replace the flash. Do you have some tips for where can be problem? Thanks
Mojmobilny Ucet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,816
